Question about Microwave Ovens
I have an Artisan mixer KSM150xxxx. This mixer has been lightly used for about 3 years. The other night, I tried to grind meat with it, but it just wasn't pushing anything through, like the motor was too weak. I took the meat grinder accessory off and tried things again, but eventually I noticed that with nothing attached, the mixer arm would not move, or move very slowly. Researching the problem, I disassembled and am now stuck. It appears that the accessory bevel gear is stuck in the housing and will not come out. All articles state that this should be able to be removed by hand. Mine appears seized somehow. I've tapped it from the outside with some tools to push it from the housing to no avail. It is resting now with a bit of WD40, but I'm afraid I'm out of ideas after that. Can you offer any ideas to remove this piece? I've already ordered a replacement part.
  • Microwave Ovens Master
  • 3,740 Answers
Here are 2 KitchenAid service manuals
This service manual is not and exact match for the KSM150 but the internal motor control parts and gears are in the the same locations and the troubleshooting procedures are the same:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
And the bigger model service manual with nice to know info:
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
These should help you remove the gear. Having said that... here is what may have happened but it is going to be a stretch for a limited use mixer. There may be some wear on the bevel gear shaft and it is catching on the bearing. Before you go hammering on it get yourself some emery cloth / sanding cloth and PUSH the bevel gear back to it's installed position and spin the gear while gripping the emery cloth. Your attempting to remove any ridges on the shaft so that will slide out of the housing.
When it comes time for BRUTE FORCE... make sure you put a small piece of wood at the end of the motor shaft. (not in the books!) I have ruined a motor driving the bevel gear out and it smashed into the motor shaft. (something you do ONCE!) Ever since then I always put a piece of wood between gear and motor when Hammering. The bearing may come out with the bevel gear too. It is almost impossibe to use a bearing press to remove this bevel gear but you can use a C-clamp if your carefully positon it. (
Thanks for choosing FixYa,
Kelly
Posted on Apr 06, 2011
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
On our new microwave there is 2 buttons for defrost. what is the difference? it does not mention defrost in the booklet we got with the unit.the mdl.# is GMH5205XVB
Using the Auto Defrost feature on my microwave oven
How do I use the Auto Defrost feature on my microwave oven?
To use the Auto Defrost feature on your microwave oven, please do the following:
  1. Unwrap food, place on the turntable, and close the door.
  2. Touch Defrost.
  3. Select food by entering 1 for Meat, 2 for Poultry or 3 for Fish, or touch Defrost repeatedly to scroll through the food selections.
  4. Enter the weight in pounds:
    Meats and Poultry can be set from 0.2 to 6.6 lb (90 g to 3 kg).
    Fish can be set from 0.2 to 4.4 lb (90 g to 2 kg).
    Doneness may be adjusted at this time by touching Cook Time.
  5. Touch Start. The display will count down the defrost time. When the cycle ends, "End" will appear in the display, and the end-of-cycle tones will sound, followed by reminder tones.
  6. Touch Cancel Off or open the door to clear the display and/or stop reminder tones.
The Defrost system has 3 categories: Meat, Poultry and Fish. It should not be used for food left outside the freezer more than 20 minutes and frozen ready-made food. Use the following chart as a guide.
Here is your owners manual:
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GMH5205XVQ_Use%20and%20Care_EN.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Whirlpool Microwave Ovens
I have other components (grinding) for the mixer, and want to know how to fit them
Normally, they attach to the top front. See if there isn't a cap facing you held in by a knob. Loosen the knob to remove the cap. The attachments go there.
--W/D--
Jan 21, 2011 | Microwave Ovens
I need to print out a manual for my Kitchen Aid Artisan stand mixer.
Go to their web site and download the manual as required.
Dec 13, 2010 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Whirlpool MH7140XFQ-1 light does not switch from regular to night
If there are 2 bulbs try swapping them around. If the night light works then you just need a bulb. Take the bad one with you and match it up at a parts store. Some actually have a dimmer circuit programmed in the board and that will not be a easy fix. Do you hear a click when you try to activate the night mode? If you cannot find a bulb or do not want to replace or repair the unit just disclose the non working light. I was in real estate for a couple years and a burned out bulb will not be a deal breaker as long as they are told up front.
Eric
Jun 08, 2009 | Whirlpool MH7140XF Microwave Oven
ON CHRISTMAS AS I MIXED A CAKE MY KITCHENAID MIXER SOUNDED LIKE IT WAS STRUGGLING, THEN IT JUST STOPPED RUNNING. MY MIXER IS LESS THAN 5 YEARS OLD AND REALLY HASN'T BEEN USED VERY MUCH. PLEASE TELL ME WHAT...
Is the warranty still valid?
Is there a recall on the model you have?
Typically the problem you describe is a problem with the motor brushes or you were mixing more material than the mixer was designed to mix and the internal thermal link failed.
The mixer is too young to develop this problem without abuse of a material flaw.
If there is no recall on it and the warranty has expired your best bet is to buy a new mixer. Repair cost will typically exceed the cost of a new on if it was a cheap model costing less than $50.00.
Jan 06, 2009 | Microwave Ovens
Frigidaire Microwave Over the Range
It could be one of several things. A defective diode, triode, high-voltage capacitor, or even a faulty magnetron. Find your appliance model number, go to, http://www.apwagner.com and put your number in the model search. They should have breakdowns of many most current models. This way you can know what is what and what to look for. Good luck
Aug 05, 2008 | Frigidaire FMV156DC Microwave Oven
KitchenAid Superba combination built-in oven (upper: microwave-convection; lower: conventional oven). Model KEMS376 TALO. Installed 12/89. The "blower" and main "power on" light (NOT...
It sounds like a stuck relay or other controller problem.
I don't have the service data on this one, but there should be a schematic or tech sheet / mini-manual either on the back side, behind the controls, or somewhere else inside.
If you or someone you know can locate them and scan and e-mail or copy & fax them to me, I can probably give you further guidance.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 21, 2008 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
