Question about Salton Kitchen Appliances - Others
I have a Salton counter-top water heater that keeps the water hot and with aw push of the turbo button brings the water to a boil in about 30 seconds, Ir stopped working and I can`t find a repair centre. I live near Peterborough, Oshawa & Lindsay. Can you help me? Katrina Bulman e-mail..... trinab@xplornet.ca
    Scholar:
  • 177 Answers
Click on the link below ,which will take you to the Salton "Customer Care" website. On this website,they help you locate Salton service centers in the U.S., Canada, and elsewhere
http://www.salton.com/customer-care
Posted on Apr 06, 2011
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
The cooker clicks over to "keep warm" before the
You're probably using too much water. Rice cooks primarily while sitting in hot water, not while its boiling. That's why the cooker switches to Keep Warm so quickly. The correct way to cook rice is to pre-soak the rice for about 30 minutes, drain to get rid of the excess starch, combine the rice and cold water and bring the water to a boil and turn off the heat and let it stand for 15-30 minutes. That's why*- rice cookers take 45 minutes or more.
Sep 06, 2011 | Aroma ARC-914 8-Cup Rice Cooker
HOW LONG DOES IT TAKE AFTER INSTULATION TO HEAT WATER
Electric water heater typically makes 21 gallons hot water per hour.
Gas heater makes 41 gallons per hour.
If you use a timer on electric heater, it will make enough hot water for shower in about 15 minutes summertimer and 30 minutes wintertime. So incoming water temperature is a factor.
If your water heater is not full of water before turning on electricity, then elements will burn out.
Also the ECO might be tripped out: open top cover and push in red reset button.
How to troubleshoot electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Apr 18, 2011 | RELIANCE ELECTRIC WATER HEATER
Why is my Rheem water heater making a "hissing" noise?
It is boiling the water. Turn it down. Look on the side and remove the small cover to expose the thermostat Turn it counter clock wise to reduce heated water temp.
There may be two.
After an hour or so test the hot water and see if you can keep your hand in the flow of all hot water. If it
is so hot it will burn you it is still too hot. 170 is hot enough. That is slightly painful and will cook the skin
Feb 08, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
No hot water
You posted under Rheem 40 gallon electric water heater, which is two-element 240Volt heater.
If this is not your heater, add a comment.
If you suddenly have no hot water, that narrows the suspect list.
Step1:
Check for tripped circuit breaker.
Open top cover on water heater and push in reset button on upper thermostat.
If reset button is tripped out, and will not push back in, then replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Put ear against tank and listen for bubbly-fizzing sound that says heater is ON.
If reset is not tripped, then move to step 2
Step 2: use tester or multi-meter and test across top two screws on upper thermostat for 240Volt.
If heater is not getting 240V, then test circuit breaker.
Move water heater wires from 240V breaker to another same-amp 240V breaker and see if that restores power.
You may need to replace breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
If problem persists, then you might have a line problem between breaker and water heater.
Open cover on top of heater, and check connections on top of heater.
Step 3:
If heater is getting 240V, then upper thermostat or upper element is bad.
I suggest 30 minute troubleshooting which could save you a service call, and will be valuable information in the future:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have sta kleen 805 , have power,240 v no hot water
If I understand correctly, your water heater circuit tested for 240 Volts.
1) If circuit has power on one leg of the 240V circuit, water heater can appear to have electricity, but won't turn on since 240V needs both legs to complete the 240V circuit. Solution: test for 240 across top two screws on upper thermostat.
http://waterheatertimer.org/B220C.html
2) ECO reset button tripped on upper thermostat. Solution, push in reset button. If reset will not reset, then replace upper thermostat. I usually replace both upper and lower thermostats at same time: cost $28. Buy parts from home center or hardware store. Be sure to put factory-insulation and covers back so thermostat is not exposed to cooler outside temperatures, that cause hotter water than set point.
3) If ECO reset button keeps tripping, then keep resetting until you can test water heater parts. Spend 30 minutes and do complete troubleshoot on tank.
Buy cheap multi-meter from home center. When test calls for checking voltage, rotate dial to 240-250-277 VAC. When test calls for checking continuity or elements, rotate dial to Ohms (upside down horseshoe is ohms).
Dec 29, 2010 | RELIANCE ELECTRIC WATER HEATER
Rheem warrior glass serial num-rh1098154699 model num-71-40d b That is all the information i collected off my hot water heater we have no hot water at all and i dont know how to fix this problem...
The label would also say if water heater is gas of electric.
That would be helpful information that could lead to troubleshooting.
Serial number tells us water heater was made on Nov 1998, which tells us the manual will not be on the Rheem website.
So if you have electric water heater, and no hot water.
There can be 4 causes.
1) Circuit breaker is not delivering 240 to water heater. Test top two screws on upper thermostat to see if tank has 240V.
2) ECO red reset button is tripped. Open top cover on tank and push reset button.
3) Upper thermostat is bad. Replace thermostat.
Nov 24, 2010 | Water Heaters
No hot water. Circuit breaker not the problem. Which plate do I open to check the eco?
Remove access panels on water heater's side the top thermostat has a red reset button on it.
Press reset button and it will take about 30 mins or more to get hot water. If you have a meter or test light check wires to elements for power.
This would be the first thing to check on the water heater.
May 21, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
How do I light my pottertn kingfisher pilot as its gone out? Keep pusing the ignite button but nothing is happening
Push also the gas button and hold in until pilot lit and then for some seconds [8-30] after until the thermocouple is hot enough to tell the boiler to light the main burner
Dec 16, 2009 | Stiebel Eltron DHC Instant Tankless...
Kitchen Appliances - Others Logo
107 people viewed this question
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Robert Plante
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
