Question about Sony VAIO FZ Series VGN-FZ140N/B Notebook
Malware infection, now when i mount my HDD externally, the only seen data is "i0.sys and MSDOS.SYS" help?
    Scholar:
  • 177 Answers
Hello denthar:
First I should tell you that Sony has an alert about counterfeit memory sticks.This may be the cause of the problem,I'm not sure.
also ,if you're using "Webroot Spy Sweeper" Sony has a Windows update to improve compatibility with Webroot Spy Sweeper.Clikc on the link below:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFZ240NB&upd_id=3344&os_id=29
Posted on Apr 06, 2011
How to mount volume as Root in Ubuntu 12.04
Re set to XP NTFS then install 12.04 as a second OS.
Aug 05, 2014 | Buffalo Technology Buffalo MiniStation...
Toshiba 451c "can not find HDD data" message
Had the same problem and solved inserting and extracting the card a whole bunch of times and blowing hard inside the slot. You can also try using the rubber to clean the contacts of the SD. God luck.
Nov 22, 2013 | Toshiba Office Equipment & Supplies
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Atapi.sys
Atapi.sys is also a popular infection target for many Trojans. You may get stop codes of 0x00000007A, 0x00000008 and especially:
0x0000000A (0x00000000,0x00000002,0x00000001,<anything>)
which requires a virus scan like AVG 8.5/9.0 to fix since the infected driver has already modified many other files in your system.. (Remove the drive and put it in another machine and then scan it.)
Jul 25, 2009 | Compaq Computers & Internet
I have troubles with a printer eSutudio4511. Code
f100 is a hard drive formatting error
[F100] HDD format error
(1) Check if the HDD is mounted.
(2) Check if the specified HDD is mounted.
(3) Check if the connector pins of the HDD are bent.
(4) Check if the connectors CN116, CN132 on the SYS board is disconnected.
(5) Replace the harness.
(6) Format the HDD. (Key in "2" at 08-690.)
(7) Replace the HDD.
(8) Replace the SYS board.
step 6 is turning the copier on while holding 0 and 8 til it beeps type 690 and hit start, this will format your hard drive, more than likely it is bad physically but you may get lucky
Jul 02, 2009 | Toshiba e-STUDIO 4511 Printer
Unable to boot into windows
what are the things that you added recently, hardware(additional hdd, memory, video card) or software (antivirus, office, etc games.) try running a hard drive diagnostics, usually computer manufacturer install a hdd diagnostics on their BIOS that you can run. hit me back on the results.
Apr 28, 2009 | Dell Inspiron mini 9 - Black , Intel® Atom...
Gone into safe mode cant change mode?
1. Click Start, point to Find, and then click Files or Folders. 2. In the Named box, type msdos.sys. 3. In the Look In box, click the drive on which Windows is installed (usually drive C), and then click Find Now. 4. Right-click the Msdos.sys file, and then click Properties. 5. Click to clear the Read-Only and Hidden check boxes to remove these attributes from the Msdos.sys file, and then click OK. 6. Right-click the Msdos.sys file, and then click Open With. 7. In the Choose the program you want to use box, click WordPad, and then click OK. 8. Do one of the following: • Delete the BootSafe=1 line.
-or- • Change the value in the BootSafe=1 line to BootSafe=0. 9. On the File menu, click Save. 10. Right-click the Msdos.sys file, and then click Properties. 11. Click to select the Read-Only and Hidden check boxes to set the attributes for the file, and then click OK. 12. Restart your computer.
Apr 16, 2008 | Video Cameras
D:\ application can not run in Win32 mode
hi
go to start-run c:
if u can open it your sys is malware infected if u hace winxp sp2 pro and fat32 or ntfs partition.
scan your sys with avast ,qiuck heal and symantec update
Mar 26, 2008 | PC Chips (M925G) Motherboard
Armada E500
using edlin you can enter for config sys device=c:\dos\himem.sys device=c:\dos\emm386.exe noems device=c:\dos\cdrom.sys /d:mscd001 /l:e for autoexec bat @c:\dos\mscdex.exe /d:mscd001 ----------------------------------- config sys himem.sys is the upper memory manager emm386.exe is the 'gate' to allow access or combine all of it noems turns off expanded memory cdrom.sys is the CD Driver - yours may have a different name /d:mscd001 refers to the name of the CD Rom Drive (generic) /l:e refers to the drive letter (e:) to designate for the CD Hope that helps If used, rate me
Nov 11, 2006 | Compaq Armada E500 Notebook
Sony VAIO FZ Series VGN-FZ140N/B Notebook Logo
64 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
