Question about Miele Novotronic Premier 500 Front Load Washer
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
I have a Miele Washing machine (premier Novo) which I have had for a number of years, and when I switch the machine on, I get water comming out of the bottom LHS filer trap unit!!! can any one help? I've checked the top unit and removed and cleaned out the conditioner unit, I have also unscrewed the filter thing in the lower LHS dront oof the machine behind the flap, and seen what looks like a "Y" type of plastic which rotates freely and has 5mm movement back and forth.. can anyone help???
Hi, I have a Miele Novotronic W 827 washing machine. I put sandy towels in, which seemed 2 have blocked it so I opened the filter and cleaned out the sand, now the filter is tightly screwed back on but evertime I turn the washer on, water pours from the small drain at the side of the filter. I am assuming that Ive lost the cap that goes on the drain but where do I get a new one if this is the case??
  • simonwhatele Aug 11, 2008
    yes i to have a miele w 827 opened the filter and now the water is coming out of small rubber tube next to it
  • 122 Answers
The panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Cleanout any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Posted on Nov 28, 2008
  • 4,889 Answers
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Aug 21, 2008
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Leak from tap at front of machine
the filter may not be sitting right in its slot - an obstacle may be keeping the filter from being seated all the way - once the filter is fully seated, it blocks the water to the front tap
Oct 27, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Miele washer-dryer
you have activated the float switch in the base of the unit due to a water leak. this could be just excess detergent or an actual leak. if you tip the unit forward with some towels in front this will drain out the water. try running again with no detergent. if it doesn't show WPS after a couple of washes then you are ok. then change your detergent.
May 31, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Apr 05, 2008 | Miele Novotronic Premier 500 Front Load...
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Feb 17, 2008 | Miele Novotronic Premier 500 Front Load...
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
816 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
