Question about Kitchen Ranges
The Dryer is a Frigidaire Affinity Model AE06500CFG0. It is a 2007 model. I have to redo the drying because it does not totally dry. I cleaned the back of the dryer, the hose and the trap near the ceiling and the pipe which leads to outside the condo. I also moved it away from the wall for more circulation. I do see the element on at the start of drying. What else can I do before I call for service.
rdial54
  • 14 Answers
SOURCE: dryer will not dry cloths
Did you check the relay switch?
Posted on Sep 03, 2008
  • 686 Answers
SOURCE: not drying in one cycle
pry the top up at the corners and then open the top. now look inside the front panel about 4 inches down on both sides and remove the 2 screws or hex heads holding the front to the cabinet. Remove door switch wires and remove front, carefull drum will drop slightly, you may want to lay it on it's back before removing front panel. from there if you have posted right or close to right model number, the 3 screws you see in the drum, remove them after undoing your belt. remember how you undo the belt so that you can put it back on the right way. Pull drum up out of cabinet and there you will see your heat element. from this site www.repairclinic.com it shows a double element. Might be only one half working causing the lenghthy dry time if this is bad replace it you'll know if one half is bad. Clean all you can while apart you can also slide out the rear bearing out of the bearing cup and apply some high temp grease there. If your element is good change the thermostat. from the looks of this belt make sure the grooves are facing up on the drum or it won't go back on right on the motor and tensioner pulley. I hope this helps you and Good luck.
Posted on Apr 06, 2009
canbruce75
  • 1776 Answers
SOURCE: my hotpoint dryer takes forever to dry We have
You will have to access the dryer to clean the internal ductwork. If the venting is good, another thing that will cause a dryer to take a long time to dry is a faulty high limit thermostat. It is a small, round, black device mounted on a plate and attached to the internal ductwork with two screws. While inside, also check the thermal fuse and heating element. These can be checked with a multimeter or ohm meter for continuity. If a component does not have continuity, then it is defective and will need to be replaced. Sure hope this helped and best wishes.
Here is a pic of thermal fuse and high limit thermostat to help you out.
Posted on Jul 31, 2009
beltronic205
  • 1466 Answers
SOURCE: I have a Hotpoint dryer model DLB2880DALWH serial
Its a twin element. Sounds like one side has gone so only working with one element..Should be located back panel or front of machine take off lid to check this good luck.
Posted on Oct 31, 2009
dmftrucker
  • 1922 Answers
SOURCE: This is an electric dryer. Over the past week when
one of 3 things could be wrong/1)dry,tight motor bearings/2)drum bearing bad/3) bad motor windings,remove belt off drum and see if anything turns hard i.e. motor,drum each one isolated then run motor w/o drum belt on drum and see if motor gets overly warm or hot especially around the bearing ends
Posted on Nov 17, 2009
How do i fix dryer taking long time to dry
BAD HEATING ELEMENT. I believe that particular model has a ring type heater coil; very effective but fragile. The dryer must be disassembled until you see the entire heater coil, I've attached a photo. The replacement is less than $80 via Amazon Prime, I know, I've done this. The kicker is that the coil was still putting out a little heat but taking forever to dry. You're just asking for a fire or a total breakdown which could adversely affect your control board (not cheap). Hope this helps. 5307dbc3-6273-485b-aaec-414a05b9c79c.jpg
Jul 13, 2014 | Frigidaire FAQE7001LW Affinity 7.0 Cu. Ft....
How to get the error code test on Frigidaire affinity model FARE1011MW
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Why is my Affinity dryer not heating as well as it was put new dryer hose in back just taking touble time to dry a small load of clother & I double spin the load also
Good Morning Friend,
I understand that your Frigidaire Affinity dryer is taking double the time to dry a small load of clothes. I also see that you have put a new dryer hose on the back of your appliance to try and correct this issue. I suggest making sure that you have also cleaned out the lint filter as well as where the lint filter sits. You can clean the lint filter by running it under the hottest water you can stand and using a cleaning brush, gently, to remove any build-up. You can clean where the lint filter sits with a small attachment on your vacuum. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer shuts off after a couple of minutes, md ll the lights flash. If you place on imer drying it will work. This doesn't happen every time, but is a pain when it does. I've totally clen out the lint from...
I understand that your Frigidaire dryer shuts off after a couple of minutes, and all the lights flash. I also see that it works on timer drying, and that you have cleaned the lint out from the entire system. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Return power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. If further troubleshooting is needed, I ask that you please leave the model number of your dryer in your comment. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity dryer (8months old) dries fine, but always has heavy moisture on the inside of drum, and door.....didnt do this when purchased.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 18, 2010 | Frigidaire Dryers
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
