Question about BlueTrek G2 Consumer Headset
Instructions please no instructions for the procedure for setting bluetooth connection to the phone!!!!
  • ttara_43 Nov 06, 2008
    How do I enter the 2 voice phone numbers that can be used to call via the Blue Tooth and just where is this done.
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
BlueTrek > G2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 06, 2008
SOURCE:
How can I get it to work from my I pad and how do I know it is fully charged
Is your speaker Bluetooth-enabled ? If it is, read the instructions in the set up guide on how to connect a Bluetooth-enabled audio source (phone, tablet, iPad, iPod). If you are asked for a passcode/passkey during the procedure and none is provided in the instructions, enter '0000' or '1234' (without the quotes).
Jan 02, 2015 | Audio Players & Recorders
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Jan 27, 2011 | Nokia 2690 Cell Phone
Internet setting on samsung E1410
Hi there ,
It is possible to connect this phone (E1410) to the PC for Internet facility. You just need a bluetooth device.
I have successfully done it on my Airtel sim card using MO (Mobile Office) package.
Follow these steps-
1. Don't call the Airtel Customer Care to activate Mobile Office Setting. Because they will tell you that your handset does not support automatic MO setting.
2. In your phone go to browser and go to Browser Settings
3. Create a New Profile with the Name- Mobile Office
4. Home Page- http://www.google.com
5. Set the Proxy as- 202.56.231.117
6. Set the Port as- 9201
7. Bearer- GPRS
8. Go to Advanced Settings and type the APN- airtelgprs.com
9. Log in ID and password no need.
10. Recharge your your phone with any GPRS (Mobile Office) packages Rs.22 (200MB)/ Rs. 98 (2GB-30 Days validity).
12. From your mobile dial *567*11# (This is must)
13. Now your MO is activated. Now turn off your Phone, Remove the Sim card and turn on again.
Please cancel the mCheque msg. if it appears after restarting your phone.
14. In your PC -Install the Bluetooth Driver.
15. Right click on the Internet Explorer-Properties-Connections
16. Select the Bluetooth DUN Connection
17. Click on Settings
18. Set the proxy-202.56.231.117 ;port as-9201
19. Click -OK, Apply - OK.
20. Now go to control pannel and double click on Phone and Modem options.
21. Click on Modems tab.
22. Select Bluetooth DUN Modem
23. Click on Properties
24. Click on Advanced Tab
25. In the Extra Initialization Command box paste the following command line-
AT+CGDCONT=1,"ip","airtelgprs.com","",0,0
26. Click OK, then Apply-OK.
27. In your phone turn on the Bluetooth
28. Insert your Bluetooth Device in Your PC and connect Your phone through the Bluetooth software
29. Click- Bluetooth Dial up Networking Service on your Bluetooth Software
30. The dialing number is *99#
31. Remember the connection may not done for the first time. So you may need to try more and more. Because the Airtel lines are always busy. Sometimes you may need to unplug your Bluetooth device and
exit your BlueSoleil from the Quick Lunch bar and Restart the Procedure. Remember this is the only procedure
for Airtel (MO) users. Try and Try and if it is connected the open any browser (I prefer- Mozilla Firefox) and open- www.google.com. Remember in some cases, it shows a false connection and the website will not open.
In such cases, Disconnect your Dial Up connection and Re-connect it. If any message apper in you phone, then exit it.
32. To check Mobile Office Package balance and validity dial- *123*10#
32. Remember I am sending this information to the internet via Connecting my E1410 mobile to my PC using Bluetooth device.
33. If you are successful, please say a little word-"Thanks
Sep 26, 2010 | Samsung Lands Phones
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
LGCU720 shine phone. Bluetooth is not working
did you do it the correct way ,recheck your procedure and settings ,follow the instructions here http://www.wireless.att.com/support/deviceTutorials.do?universe=att&deviceId=10290&tutorialsCategory=Bluetooth+Set+Up&tutorialId=645050
if the problem still persisits then its a hard ware problem with the blue tooth device
Jan 04, 2010 | LG Shine CU720 Cellular Phone
I want to add a bluetooth headset
First you have to buy one, :) the procedure for adding bluetooth is to enable it in your phone, in settings, turn it on, then the phone has to search for the device, when it finds it, a name will pop up in it's search, then you have to tell the phone to "pair" the device and it will work. Be sure your bluetooth is turned on. To make the bluetooth device available for pairing, usually you hold the button down on it for 8 seconds til it beeps or changes color. To use your phone normally after, you have to shut off the bluetooth or else the speaker and mic won't work on the phone - it will go to the bluetooth. Bluetooth is basically a short range radio signal that works for about 10 feet, the phone sends and the device receives.
Aug 31, 2009 | Cell Phones
How to connect to internet with my cell phone motorzr max v6
Using your cell phone as a modem is perhaps the most overlooked of all Internet connection options. But a mobile phone Internet connection, whether as a tethered modem or, using bluetooth, a wireless cell phone Internet connection, is easy to set up, and with a laptop and cellphone you can check email and surf the web from anywhere, any time, with the Internet in your pocket!
Here are the basic instructions for creating a mobile phone Internet connection. The instructions are for a cell phone with bluetooth (which most cell phones these days have), but if your cell phone doesn’t have bluetooth you can buy a cable to connect your laptop to your phone from any cell phone accessory provider. Conversely, if your cell phone has bluetooth but your laptop does not, you can buy a small USB device which will enable bluetooth on your computer.
Feb 20, 2009 | Motorola Mobility MOTORAZR maxx V6...
BlueTrek G2 Consumer Headset Logo
354 people viewed this question
Top BlueTrek Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a BlueTrek Radio Communication Expert? Answer questions, earn points and help others
