I own a Lanier Messenger Model P145 that holds 4 minitapes. There is a strange-seeming intermittent problem happening. The light will show there is dictation, the tape is rolled forward, but no voice on the tape, no emark, no nothing. Yet other times the dictation is there as usual. ALSO, I have lost the instructions for dictating and would like to get another copy of that, but where can I get them?
    President:
  • 1,768 Answers
1. Your device possibly has a broken voice connection from the dictation microphone or the record heads need cleaning.
It sounds like there is an intermittent connection between the dictation microphone and the recording heads.
2. Your unit will need to be serviced by a tech. This may require dis-assembly and and rewiring of the microphone. This is an intrusive procedure.
Posted on Apr 07, 2011
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
My Lanier P145 microcassette dictaphone will not pick up when dialing in
Look under the front of the unit and there is a tel ans switch this must be on to enable the unit to answer the call
Sep 19, 2012 | Lanier Audio Players & Recorders
Interior refrigerator light stays on - melted housing. Seems to be intermittent - replaced light housing and bulbs after first melt down- 3 months later same thing happened. Did the drill again and it...
Greetings.
yes, its your control board..they operate the light as well and everything else...this happens all the time...If you need more help..Please let me know, Bruce
Feb 03, 2011 | LG LFX25960ST Stainless Steel French Door...
Intermittent problem oil pressure dropping off
the oil pressure relief valve may be sticking causing a fluxuating oil pressure .this valve allows acess oil to flow back to sump hope this helps!
Apr 11, 2010 | 1997 Jaguar XJ6
LANIER COLOR COPIER MODEL LD345c Funtional Problem SC541
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Apr 07, 2010 | Lanier 1205 Copier
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
Audi A6 radio intermittently cuts out
I've had similar problem with AUDI A6. AUDI replaced phone controller, covered by 70% by manufacturer. Total cost 400 Euros, repir was done in Germany.
Aug 27, 2009 | 2006 Audi A6
When i switch on my digital Panasonic TV (Model TX-32LMD70)using the remote control from standby (red light showing) the green (on light) flashes and then nothing happens i.e. the television does not...
Is your TV still under warranty? This problem seems common on this site with the Panasonic brand. I really can't say what exactly is causing this problem, but it seems like something in the power circuit board is faulty. My advice would be to call Panasonic's Technical Support Hotline and speak to a Technician. It could even be a problem that has warranted a recall of that particular model. The number for Panasonic's Hotline is 1-800-211-7262. Or, you can contact them via e-mail @ www.panasonic.com under "Get Support". Hope this helps...
Sep 08, 2008 | Panasonic Televison & Video
267 people viewed this question
 Grubhead
Grubhead
