Question about Acer Computers & Internet
Acer 501t Set LCD Panel ID - Acer Computers & Internet
  • gmbrezzo Aug 06, 2008
    I transfered a working LCD from non working acer laptop to a working one that had a broken LCD. on startup the new LCD worked fine. I got a bad battery warning on post. I turned off the notebook, pulled the RTC battery from the old notebook and put it in the new one, (at same time exchanged the HDD).
    Turned on the new notebook and the screen did not light up.
    I plugged in a CRT monitor and that worked fine. On reading the field service manual the instructions say to set the LCD panel ID using the Utilities diskette. This I do not have and cant find a download anywere. Please help.
    Regards
    Graham Brezzo
Hi Graham,
lost contact with you over the years... if you worked in AgInfoTech some time ago? would love to get back in contact with you...
email me on: annefernee@hotmail.com
Cheers,
Anthony.
Posted on May 17, 2010
    Sergeant:
    Champion:
  • 293 Answers
Wat is really the problem?
Posted on Aug 06, 2008
  • Allan Ocenar
    Allan Ocenar Aug 07, 2008
    i think your lcd screen in your laptop is defective already, but the cpu,mb mem is still ok.
Acer v700 fan fail
you need a new fan for the ACER v700
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Nov 10, 2013 | Acer V700
Acer p5270 no function
Have a good day!
have a nice day!
Jan 29, 2013 | Acer P5270, P5370, P5370W Projector Lamp -...
Acer red light battery
1) http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Yes, I know. Aspire 5100 series of Notebook PC, not the Aspire 5230 series. I am looking at the Service Manual for the Aspire 5230 series right now, and the above link is a good basic pictorial guide.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Drop down to the subheading - Aspire 1200. (1200 in Blue)
Go down to the 6th line, scroll across, and left-click on 5230 in blue.
(Takes few seconds before the first page comes up.
In the PDF file page number box at the top, go to Page 119)
2) If you mess up with the connection of the LCD Panel Cable, to the LCD Panel, (On back), your laptop will not power up.
Those tiny contact pins on that cable's connector, must line up exactly, and be plugged in tightly to the LCD Panel.
Not plugged in tightly? You won't see it visually. You have to physically check.
Also use the old tape that was there, to tape over the connector once installed, on the back of the LCD Panel.
Ripped it all the way off? Oops! Use some new tape. (Not duct tape, scotch tape, or medical tape. Box tape with strands in it)
3) Connector of LCD Panel Cable, connected tightly into motherboard?
4) Screen Inverter wires connected? Connectors are keyed differently from each other, BUT, are they connected correctly?
5) Why was the LCD Panel replaced? Damaged? Did the LCD Panel Cable receive damage? Did you perform a cursory visual inspection of it's sheath, at least? Sheath showed ANY damage, did you perform a continuity check of each wire in the cable, with a multimeter set to Ohm's? (LCD Panel Cable unplugged from motherboard, and LCD Panel, of course)
6) If there was damage, did the screen Inverter receive damage?
7) Connect the LCD Panel Cable's ground wire/s back to THE ground screw/s? Good bright clean connection area for those eyelet ground terminal/s?
8) Did you crossover the new LCD Panel to the old LCD Panel, to make sure it is a direct replacement?
NOTE*
A screen Inverter, and an LCD screen, (LCD Panel for Acer), are a MATCHED unit.
9) AC adapter plugged into power, and plugged into laptop, along with the battery?
Post back in a Comment, and if none of the above is the problem, we'll go on from there.
Regards,
joecoolvette
Jun 07, 2012 | Computers & Internet
Looking for the manual booklet for this tv set please! asap! thank you in advance.
While this site does ask for an email address and has an image security validation (you have to type the numbers shown) I believe you will get the manual in a pdf format.
http://www.retrevo.com/support/Acer-AT4220B-TVs-manual/id/843bh147/t/2/
Good luck
Dec 27, 2010 | Acer AT4220B 42 in. LCD TV
I can barely se the desktop,it is very dark. acer aspire 1710
It sounds like you are or have lost your backlight. In most cases this can be the inverter, it sits under the lcd panel behind the lcd bezel. Unless the unit was dropped or suffered a shock of some kind, I don't think it would be a broken ccfl backlight bulb. Check for loose connections at both ends of the inverter, sometimes these connectios get pulled because they run through the hinges and can get caught or rubbed bare. Below is the link to the service guide that will help in the disassembly. Inverters can be bought on Ebay for under 25 bucks. There is always the chance that this is the ccfl bulb, it is built into the lcd panel itself and therefore it is more cost effective to replace the entire panel then try to disassemble the lcd panel and replace the ccfl bulb. Good luck
http://tim.id.au/laptops/acer/aspire%201710.pdf
Jul 25, 2010 | Acer Aspire 1710 Notebook
Problem with Acer extensa 501T
the lid is blocked? hmmm..check under the screen, where the lid engages the sliding button, to open it. something may have fallen into that opening.
http://tinyurl.com/6qcpgy
Aug 17, 2008 | Acer Extensa 501T Notebook
Caller ID display
might be the IP funtion is on. this is not available in the USA. press SET/SAVE, press Up to select "SET 4 AUTO IP", press SET/SAVE to select, press UP to change setting, press SET/SAVE to confirm. if you'd like a copy of my manual for the phone, email me at all8upinwv@yahoo.com and i will send a copy in 2 different formats so you'll be sure to be able to open at least one of them. hope i helped.
tammy
Apr 14, 2008 | Innovage Speaker/Caller ID* LCD Touch...
HD Where is he ?
The HD is underneath the palm rests in a drive cage. You'll have to take the laptop completely apart to get to it.
Usual steps:
- Remove all screws from the bottom of the laptop
- Remove keyboard from laptop
- Remove any other indicated screws to disengage top and bottom of plastic shell
- Remove top plastic shell
Nov 13, 2007 | Acer Extensa 501T Notebook
Computers & Internet Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
