Question about Cobra Radio Communications
HI THERE, I HAVE A COBRA MICRO TALK. MODEL PR3500DX SERIAL H503020616. I AM HAVING A PROBLEM. I CAN HEAR HIM WHEN HE CALLS ME . BUT WHEN I PUSH THE BUTTON TO CALL HIM HE CAN NOT HEAR ME. IS THERE A RESET BUTTON. ALSO CAN I PULL UP A MANUEL ON LINE OR CAN YOU EMAIL ME ONE I CAN PRINT. WHAT WENT WRONG? DO YOU HAVE COBRAS PHONE NUMBER. THANK YOU,
4 Suggested Answers
SOURCE: Long range mode
we bought a cobra hl-200p its says 2mile range but it doest mit the standard range for about 50 feet we can no longer transmit and when we set to max range we only hear loud static can you help us on this problem? tnx we only have 2days warranty
Posted on Jan 14, 2008
dirinda89
  • 214 Answers
SOURCE: Cobra Micro Talk Model GA-CL
Here's the link...
http://www.fixya.com/support/p130832-cobra_microtalk_100_frs_walkie_talkie/manual-1763
If this helps plz rate this f'ixya' Thank you kindly.
Posted on Feb 10, 2009
micromatikal
  • 2777 Answers
SOURCE: have Cobra Micro Talk Walkie Talkies and have lost
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Posted on Oct 12, 2010
I'm searching for a owners manual for Cobra Micro Talk H302015077
it;s a pmr nothing only
its send and transmit on pmr 446 mhz
left volume up down
right 8 channels
call is beep
there could be a subtone on a channel, selective call to reach users with same channel and subtone.
if subtone is off you can hear everyone on the channel.
May 01, 2015 | Cobra Radio Communications
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Can a Motorola talk about 250 talk to a cobra CXT 195. They can hear me from the Motorola I just cant hear them
Your code (PL code, interference eliminator, quiet call) is not programmed the same on both radios. The Cobra appears to be set to open squelch (no code). Set your Motorola code setting to zero (off). This should solve the problem.
Feb 18, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
How do I connect sterio earphones to one of my Cobra micro talk CXR825 units just to be able to hear transmissions in both ears but not to have the microphone connected
Hi Bob,
Solution is simple and affordable, just take your radio to your nearest radio shack or similar store and ask for a stereo to mono adapter to fit into the the extension speaker/ headphone point on your radio, if it has one fitted, and I assume it does.
I hope you find this useful.
Cheers,
Peter
Jan 13, 2013 | Cobra CXR-825 MicroTalk CXR825 Two Way...
One of my Cobra Microtalk radios is stuck on RX. Everything else seems to work. What could be the problem?
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
Jul 05, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
One micro talk 1 can ring the other and talk & one does not ring
the other set is not transmitting but its able to receive,
so a transmitter be checked.
Mar 29, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra microtalk Pr 17 OC
Dear sir,
Open the unit & check PTT switch check it by manually closing the circuit ..it will come in tranmission mode .i think ur PTT switch is out of order & nothing else .
Regards
Raj
Dec 11, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Motorola Talkabout T5400
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Apr 16, 2007 | Motorola Talkabout T5400 (14 Channels)...
Radio Communications Logo
66 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
