Question about Pantech Matrix Cell Phone
My pantech c740 keyboard suddenly stopped working. The only thing I can do is make calls. I can't even accept a call when the slide is open. I believe the only button that is working is the "red"button.
  • cmmfish Apr 06, 2011
    my pantech c740 keyboard suddenly stopped working. The only thing I can do is make calls. I can't even accept a call when the slide is open. I believe the only button that is working is the "red"button.
  • 6,993 Answers
I think your phone's keyboard/keypad is defective, that's it's not responding. Also, it is possible that the flex of the keyboard/keypad may have loosed contact.
So, now you will have to disassemble the phone to actually find out if the keypad is intact and has no damage flex.
Turn of the phone, remove the battery, get a torx screw driver, remove all the screwing holding the phone together, use a flat torx screw driver to pry the phone case from the side to get it apart and check the keypad. Make sure it is intact and try again. You don't need to couple the phone back before test it. You can put the battery and test it before put the phone together.
If you feel you cannot perform this task on your own, you can call a family or friend that you feel can assist you. (two heads are better than one).....
If you don't find any obvious problem with the keyboard/keypad or it's flex, then you will have to replace the keypad.
I hope you understand the above.
Good luck.
Posted on Apr 06, 2011
  • 2,574 Answers
Generally, when a cell phone's keypad is not working properly it could be one of three different reasons:
1- Due to shock from a drop, circuitry is damaged thus no matter how hard you press you will never get the phone to register it. This issue is one that a certified technician would have to take care of and is nothing that we can fix here as it would be time consuming and expensive.
2- Because of moisture or heat, again, the circuitry could be damaged. Nothing to be done here really. The only thing to try best for a phone that's been subjected to moisture is to place it in a sealed container with rice. The rice will draw out the moisture and if there was not too much damage the phone should work fine
3- The phone's keypad membrane is broken or dented.
Ho can u jailbrak a stright talk sims card to go in the pantech matrix
you can't jailbreak a sim card but you can unlock the pantech
Pantech Matrix C740 Unlocking Instructions
1. Turn on phone with accepted SIM card
2. Press the following keys: *#865625#
3. A SIM Unlock Menu will appear, press OK
4. Enter 8 digit Unlock Code
5. Re-enter Unlock Code (8 digit code)*
6. Phone will display Unlock Process Complete. Press OK.
7. Phone is now unlocked
the website i used to get unlock code is
http://www.forum.shaarpmind.com/showthread.php/222771-5-pentech-unlock-code-100-free/page30 you will need you imei number and they can give you unlock code for free.
In order to unlock your phone, they will require your IMEI number. You can find this by pressing *#06# on your phone as if you are making phone call.
Nov 06, 2011 | Pantech C740 MATRIX
Tip
Pantech C740 Matrix Owners Manual Download
Download Pantech C740 Matrix Owners Manual
Have you misplaced your Pantech C740 Matrix Owners Manual?
Would you like a digital, searchable, pdf version of thePantech C740 Matrix Cell Phone Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 21, 2010 | Cell Phones
Tip
I hope that helps.
on Apr 21, 2010 | Pantech Matrix Cell Phone
Pantech c740 unlock code Imei # 011917001521014
Get the unlocking service from your network provider or you may get it from www.mobile-unlocker.com . After getting the code, you may follow the instructions here,
1. Switch ON your Pantech C740 with its ORIGINAL SIM card.
2. Type *#865625#.
3. A SIM Unlock Menu will appear, press OK.
4. Enter Unlock Code.
5. Re-enter Unlock Code.
6. Pantech C740 will display Unlock Process Complete. Press OK.
7. Your Pantech C740 is now unlocked.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech C740.
If you have any doubt in this, visit this Mobileunlockguide.com.This will provides the complete guidance for you.
Jul 25, 2011 | Cell Phones
Pantech c740 unlock code imei 011917001521014
Get the unlocking service from your network provider or you may get it from www.unlocking4u.com . After getting the code, you may follow the instructions here,
2. Type *#865625#.
If you have any doubt in this, visit this http://www.mobileunlockguide.com/pantech-c740 .This will provides the complete guidance for you.
Jul 25, 2011 | Pantech Matrix Cell Phone
I need a code for my pantech matrix c740
What type of code do you need ? Security code or unlock code.......
If you want the unlock code means get from this site http://www.onlinegsmunlock.com/pantech-c740/rs7wp9/ , it provides the step by step instructions and simple methods for unlocking your pantech mobile at a safe way.............
Jul 07, 2011 | Pantech Matrix Cell Phone
Pantech c740 and it is saying emergency calls only
Most likely a new SIM card should fix the problem. Hope this helps!
Jul 16, 2010 | Pantech Matrix Cell Phone
Pantech MATRIX C740 slide hinge has come loose. How do you take the phone apart to fix? (Pantech Matrix and Duo are not the same phone)
i suggest not taking the phone apart. 5 of my friends and myself have the matrix and after flipping it a couple of times the hinges are always going to feel loose. they have felt that way on mine for over a year. and if you take it apart, the senor bars for the keyboard will go out and you will have to get a new phone or just use the number pad
Jan 10, 2010 | Pantech Matrix Cell Phone
Pantech c740 screen only shows white
Many users of the Pantech phones have been experiencing the same thing. There are a lot of default in this phone. I would suggest you to return it to Pantech and try to get a software upgrade (if there is!). Although, I would recommend you NOT to use it. Even if the Pantech exchange it for a new one, the same problem will happened in a day or two.
Jul 28, 2009 | Pantech C470 Matrix Smartphone
Pantech c740, will not stay on, w/new battery
Sounds like the phone is malfunctioning, I would probably replace it.
Jul 22, 2009 | Pantech Matrix Cell Phone
Pantech Matrix  Cell Phone Logo
107 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
