Question about Proform 520 Trainer Folding Treadmill Pftl49807
Think board under running surface has cracked. Need a new board and how to fit it. Hope you can help. Plus are there any mobile engineers to fix and service proform treadmills in the northwest England. Mark
    Problem Solver:
  • 14 Answers
Easy to do it yourself. Just mark the threads on some of your adjustment bolts.
Google icon service. Go to the parts section put in your model number, it should start with PFTL then some numbers. All your parts are there and prices. NOBODY CAN GET THEM CHEAPER!!!!
Posted on Apr 09, 2011
Water in the oil
Radiator coolant in the engine oil is normally an indication of a failed cylinder head gasket or a crack in the cylinder head or both.
Running the engine in an overheated condition will cause head gasket failure and often a crack in the cylinder head.
The problem you have is coolant is escaping into the engine's lubrication passages via the failed head gasket or head crack and contaminating the engine oil. If not fixed you will cause further damage to the engine as oil contaminated with radiator coolant cannot adequately lubricate the engine.
Running a leak down test on each cylinder will confirm the leak. In this case you are going to need to have the cylinder head removed and thoroughly checked for cracks and any warpage as well as a new cylinder head gasket fitted. The condition the engine block surface will also need to be checked.
Jun 14, 2016 | Cars & Trucks
I have damaged mobile screen how to fix?
take it to a mobile phone repair shop and have a new screen fitted
Oct 08, 2015 | Cell Phones
2003 hyundai tiburon gt
  • This requires careful application of an ez out or thread repair kit very likely these are tapered threads and in aluminum. can be tricky and should be attempted by someone with previous thread repair experience, the pipe must be removed and if the threads are not damaged you can just clean up the area and re install a new sensor ( thread sealing tape is often used) you must not get any of the tape in the oil galleries or it can plug up the flow causing engine failure. pay the money now to have it fixed correctly, or ensure who works on it is knowledgable or the cost will be considerably more, torq the fitting to the proper spec not till you think it is tight, good luck
Jul 28, 2014 | 2003 Hyundai Tiburon
I have used my wii fit plus 3 times with no problem but yesterday i did body test then went training first few games were fine then it started saying my weight was a little different than before do i want...
Yes, it's completely normal. To avoid this, try to take the BMI test at the same time everyday. If you have a big meal in between the weights, it might say that.
Also, the batteries on the board may be running low. Try with some new ones and see if the problem persist.
Also, try keeping the Wii Balance board on a flat hard surface, such as the floor. Do not use it on thick carpets since it might report bad measurements.
Hope this helps.
Aug 26, 2010 | Nintendo Wii Fit Plus for Wii
We have a motorhome and were getting engine noise through speaker
ok,,,this is an easy one to fix,,,
its a cracking or screaming sound ,,,right?
its off the car spark plugs and from the plug leads,,,
you havent fitted any serpresors to the plug leads
you can do one of two things here buy new plug leads plus the coial lead but they must be suprested leads,,,or just buy the suprested caps and fit them yourself,,,its best to buy new leads,,,when you fit them only pull one lead off at a time and fit the new lead to the one you pulled off that way you cant get in a mix up,, its very unlikely the alternator will cause a buzzing but they can at times,,,check that the radio ariel is earthed to the car body,,,it must be earthed!
Jul 03, 2010 | 2006 Sterling 825
Lcd cracked on sgh d900i how to fit new one?
hi,it could be fixed,just kindly take it to a mobile phone engineer to fix it up for you.you will needto buy a new lcd before it could be fixed.and also its a hardware problem.thanks.
Mar 08, 2010 | Samsung SGH-D900 Cellular Phone
LG Tromm dryer has a crack in the drum. Can this be self repaired and if so how?
I'm a mechanical engineer and improvised a repair as follows: rotated drum so that the weld crack was not displaced; roughened surfaces and fitted a small Stanley steel mending plate across crack (shaped plate to match inside drum surface); used PC brand "Fahrenheit" high-temp epoxy putty to bed the plate in place; covered the repair with another thin epoxy layer to provide a smooth surface which would not catch on clothes; further smoothed repair with quick wipe of solvent; most likely a temp fix but working well so far (1 month).
Nov 03, 2009 | LG Dryers
LEAKING IRON
This was happening with mine - leaving trails of water behind as well when I ironed. I took it all apart (figured it was already broken, what could I do worse?) I discovered that there is a rubber gasket around the hole that lets water move from the reservoir to the heating plate. The two surfaces (reservoir and plate) are held together by screws, which compresses and seals the gasket. The bottom surface of the reservoir section had been cracked (due to a drop on the cement floor, probably, and the two surfaces could no longer fit tightly together, the crack allowed it to flex, and water leak out. In other word, once it's leaking like that, it's time for a new iron. Sorry I can't offer a fix, but at least a explanation!
Jun 25, 2008 | Rival IR600 Iron
T-mobile wing lcd replacement
i went to www.htclcd.com for my replacement LCD only cost $55 and came with the T5 Torx screwdriver
Jan 18, 2008 | T-Mobile Wing™ Smartphone
Proform 520 Trainer Folding Treadmill Pftl49807 Logo
227 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
