Question about Proform 325 Treadmill Walking Belt
I HAVE TROUBLE GETTING MY TREADMILL TO GO. WHEN YOU TURN IT ON IT IS VERY SLOW DOESN'T MATTER WHAT SPEED YOU HAVE IT ON IT NEVER GETS TO THE SPEED AND THEN WHEN YOU STEP ON THE TREAD MILL IT STOPS. WHAT CAN I DO
I have precore commercial treadmill problem is its not taking any load its motor stops as soon as any person try get on it
Posted on Jan 01, 2014
    Problem Solver:
  • 14 Answers
Replace the belt, motor and lower electronics. Change your belt every three years and lubricate with silicone spray monthly.
Posted on Apr 09, 2011
When i start my proform 750 it doesnt slow down. It goes straight to max speed and never slows down.
try to calibrate the speed on the treadmill look in the trouble shooting section of the manual
Nov 04, 2014 | Proform 750cs Front Roller Model 299560
Treadmill
DEAR
IF IT STOP AFTER 6 OR 8 SECOND YOUR SPEED SENSOR IS NOT FIX AND ITS OUT OF SERVICE YOU MUST FIX IT SIMPLY AND YOUR TREADMILL WORK AS WELL
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 31, 2017 | Lifespan Exercise & Fitness
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Speed stays at 16.6 no matter what number you select
Dear Sir:
You have trouble with your sensor speed need to adjustment.
Run the calibration software for easy diagnose and troubleshooting
Otherwise see my personal TIPS, for diagnose
Trouble.
sincerely, God bless you.
ernesto a cuadra
managua, nicaragua c.a
Mar 05, 2012 | Proform 350 Treadmill Walking Belt
Manual to trouble shoot/run diognostics
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 30, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Treadmill won't slow down
if you look at the front roller. there will be a black device that has two wires. this is your speed sensor. Make sure it is facing the magnet on the roller.
Aug 10, 2009 | Exercise & Fitness
18 volt xrp hammer drill driver
run the drill slow while changing the speed of the drill
Mar 22, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Proform 325 Treadmill Walking Belt Logo
242 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
