Question about Epson LQ-2180 Dot Matrix Printer
I have changed the catridge, but its still cannot print. what could be the problem?
I use the tractor feeder, sometimes papers get cramped inside, any solution?
  • 417 Answers
Hi, sometimes the ribbon can get bunched up when you install them, try this, manually turn the knob on the cartridge to take up the slack and watch very closely when you install the cartridge so that the ribbon stays flat all the way down into the machine, use a flashlight and a magnifying glass if necessary.
good luck
Posted on Aug 06, 2008
  • 110 Answers
Try using a different paper feed method. Most people load from the back, try loading the paper through the front
Posted on Aug 22, 2008
  • 80 Answers
Check inside the roller, there may be obstruction in the roller that is causing the paper to be crumpled....
I have the same problem with a Kodak printer I have. I sometimes have to put more paper in or take some paper out to get it to print. It looked to me like the feeder roller was messed up.
I am going to get a new printer as soon as the ink in this one is used up.
Mar 06, 2015 | Office Equipment & Supplies
My document will not print even after changing both the color and black ink?
Does the printer go through the motion of paper coming out when you press print. If it does and still no paper then the print heads may be the issue. Sometimes they do not come on the ink catridges. given how old the printer is proll better to replace it. If it doesnt go through the motion then its a software issue and need that fixed maybe by uninstalling and reinstalling.
Mar 03, 2011 | HP DeskJet 812c InkJet Printer
Printer screen message reads turn paper lever then online single Can't get it to print
I guess you are using tractor fed paper, the type of paper with holes down the side.
The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
  1. Put the printer Offline
  2. Press Setup
  3. Press the button under PaperWay
  4. Change this to Tractor 1
  5. Press SET
If the above steps do not work disconnect the printer from the computer then try again.
For more info see the Dascom web site;
And look for the Online Single & Load section
Oct 14, 2009 | Tally Serial Matrix T2130 Printer
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
HP L7680 Print Problem
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer..
Good Luck
Jan 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Paper either just rolls through without printing or won't catch and sits there
This has occured to a 2.hand printer I just bought. First head was clogged very much. I disassembled the head, used a paper towel soaked in luke warm water to clear off the over-gooed printing head surface. It is quite easy to get the head out and back in. Unfortunately my cyan ran out during clean-cycle, so I can't say if it also cured the passing paper problem.
Jan 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer error, only prints one color
Did any of the ribbon come away, or tear when it broke, i have heard of small pieces lodging in the carriage or feeder. Check this very thoroughly as blockages can be very tiny. Check you correctly inserted the ribbon too, and it is the correct type of ribbon for your unit. (sounds silly but sometimes it ccan be that simple) try reinstalling printer, is the ribbon cartridge faulty? check it.
Aug 10, 2007 | Olympus P 400 Thermal Printer
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Epson LQ-2180 Dot Matrix Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
