Question about Sony FD Trinitron WEGA KV-30XBR910 30" TV
Same problem listed here: standby light blinking, won't turn on, bought new 7 yrs ago. Sony KV-30XBR910
  • 455 Answers
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Aug 20, 2011
My Sony Trinitron kv-30XBR910 wont turn on. It sounds like it, then like it shuts itself off again. Standby light blinks 7 times, shuts off for a sec, 7 blinks.. What's this mean? Can I fix it myself?
power supply. Check capacitors on the power supply board, replace ANY that have the slightest bulge on top, should cost you less than $10 in parts, and some through hole soldering. Ebay has capacitor kits for your TV or you can just look on sides of bad ones and replace. Try and get the same thermal rating (85C or 105C) and always get same capacitance. Voltage is not a deal breaker if you get something higher, but never lower. I'm watching a $1200 Samsung TV right now I bought for $50 and $4 in replacement capacitors.
Aug 18, 2015 | Sony Televison & Video
No turn on 6blink sometimes 7 blink code
http://www.retrevo.com/support/Sony-KV-30XBR910-TVs-manual/id/274ci674/t/2/
Manuals here!!!
Mar 05, 2013 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony tv KV-30XBR910 blink code meanings
Blinking of standby light with Sony TVs are fault indications. Sony blinking codes and faults are described in detail by this site. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Nov 03, 2012 | Televison & Video
Stand by light blinking 7 times. occassionally turns on when pressing reset and power button.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
There is a High Voltage fault or power supply fault.
Hope that helps.
Dec 09, 2010 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony Trinitron 30XBR910 Not Turning On
The three blinks code(sony error codes) indicates a problem in the power supply. In your case since you manage to turn it on after a while it may mean that you have weak capacitors or bad solder joints in the power supply.
Hope this help Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 01, 2009 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
KV-30XBR910 won't power on, 7 blinks
I have the same set, and same problem. After many hours/days of reading about this issue (which seems to be a popular one for this series and others) I have found a few sites that have detailed info on what can be done. This link is for a different set but the same issue. http://www.agoraquest.com/viewtopic.php?topic=1121&forum=34&start=80&select_page_number=9
This problem seems rampant on many Sony sets. There really should be a class action suite against them for the replacement cost of the parts which can be $400(USD) or more unless you are handy with a soldering iron.
I have a service tech coming by to look at the set soon ($75) so he can tell me what is actuall wrong with it. Once I know if it is the D-board or the usual 3 ICs that die. I will most likely have a friend of mine solder on some sockets to replace the ICs if the happen to die again.
Good luck
May 03, 2009 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
regards,
daniel.
Dec 28, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
SONY KV-DZ29M61 horizontal deflection problem
You cannot use sub parts on sony use sony parts only. Same with hori output transistors. USE SONY PARTS ONLY.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Mar 21, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
