Question about Husqvarna YTH2454 54in 25 HP Lawn Tractor
Mower is 3 yrs old and i have replace the drive belt 4 times i get about three months and the belt is so loose it will not pull the unit.
5 Suggested Answers
SOURCE: MOWER CONTINUES TO PULL AFTER DRIVE CONTROL IS RELEASED
try and slacken the adjuster nut on cable mate there shoul b 1 smwhere at top of cable near drive control lever/handle and also 1 at drives gearbox. failing that mate it could be a tensioner spring on the drive control mechanism
Posted on Apr 17, 2009
  • 84 Answers
SOURCE: im 12 yrs old need to know the plug gap on my lawn
there is a circular tool that gradually increases in size as you go. just put the gap on this tool and wen it stops that # is your gap size.d290e98.jpeg
Posted on Jun 24, 2009
jmgldsmth
  • 1869 Answers
SOURCE: I have a rear propelled sears mower
check your gear train to the wheels and the wheel hub gears
Posted on Aug 21, 2009
Testimonial: "Thanks for your time i will look at that in the morning."
SOURCE: Drive belt replacement
You may have a worn worm or sector gear.
You can turn the pulley for the transmission and see if the wheels turn that way. If they turn you may have belt run out or that cable may have come off at the bottom. Unplug before you turn any parts on the mower manually for safetys sake!
Good luck and be careful!
Posted on Jul 01, 2010
Batteries failing
one would certainly think the batteries are replaceable .
Mar 19, 2015 | Panasonic Lands Phones
Tip
When the walking belt is slipping during use.
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
on May 01, 2010 | Exercise & Fitness
Blades turn slower when deck is lowered on cub cadet 1042
Had the same problem after winter storage and couldn't find an answer anywhere. I noticed that the drive belt (not the ribbed deck belt) was loose when the deck was down below 4 and tight when it was up higher.
That told me either belt is stretched beyond the belt tensioner's or the tensioner wasn't working right. Found that the tensioner was hard to move and would stick. Greased the zerk on top of the large bolt, worked it back and forth a number of times by pulling on the belt. Problem fixed. But I'm thinking it may be time to order a new tensioner spring and belt anyway. Hope this helps someone down the road. If so pass it on. :) jerseyjimmers@yahoo.com
Jun 16, 2012 | Garden
Belt is slipping
Apr 03, 2010 | Cadence Exercise & Fitness
My YS4500 (3 yrs old) has recently been loosing power in the hydro transmission. The engine runs great, but the drive stinks. I have to ease it into drive and as it gets going it will pick up speed, but if...
Yes, what I believe you have, is a loose drive belt. this can be due to several things,1st, the drive tensioner spring may be broken, 2nd,the drive belt tensioner pivot arm may need lube, or the belt is worn out.
You did not mention the hydro making noise(whining) if that were the case i would have you check to see if the brake were sticking.
Sep 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Belt is slipping on healthrider treadmill
Apr 30, 2009 | Icon Exercise & Fitness
Belt is slipping
Jan 26, 2009 | Proform 370E Treadmill Walking Belt
Belt slipping on treadmill
Jan 06, 2009 | Exercise & Fitness
Loose Belt Drive
Remove the rear cover on the unit and see if the belt is loose. It should not stretch more than 3/4" when you pull on it. There may be an adjusting bolt on the motor to tighten the belt. Disconnect power before working on the unit!! You should have an owners manual for this unit. Check it for further information.
Ray
Dec 11, 2008 | Kenmore 22422 Top Load Washer
Husqvarna YTH2454 54in 25 HP Lawn Tractor Logo
52 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
