Question about Sony CDX-MP40 CD Player
When i turn off the ignition and on again the unit loses its radio presets. Why is this and how can i rectify it?
    Sergeant:
  • 347 Answers
Hello jim_read!
please check your wiring, there is generally a red and a orange one, one is for permanent 12v the other for ignition, since your cdp does not get any 12volt after ignition turned off it can't keep memory.
regards
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Posted on Apr 06, 2011
Testimonial: "4 THUMBS UP"
Cannot maintain preset settings.
Do you have a fresh battery in the unit? Make sure your 'reset' button inside the battery case isn't 'stuck' on (push a little pencil in there).
Fresh battery, then do a reset inside the case, do a reset to factory settings, then try normal on and off with the switch and see if that fixes it or not.
Jul 25, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
audi delta
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Mar 29, 2010 | 1997 Audi A4
When i turn the ignition off i lose all radio presets. What wire needs to be live to keep the presets??
The Yellow wire is 12volt battery constant on after- market receiver heads.
Aug 16, 2009 | Car Audio & Video
I brought my son a 1997 Audi, and the radio is in safe mode, can anyonr help me get the code?
  2. Press the P.Scan and RBDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the P.Scan and RBDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Jun 22, 2009 | 2002 Audi A6
Mitsubish 10 cd will not power off
You need to check both of the main power wires. The 12V constant is almost always yellow and fused, and this connects directly to the battery, and functions as a memory for time, radio presets, etc. The Red wire is the 12V switched, and it needs to be hooked to an accessory wire or the ignition wire, whichever your preference. The 12V swithced is the prompt for the radio to turn on and function, and if it is connected to the battery, the radio will never go off unless turned off physically.
Jun 13, 2009 | Car Audio & Video
Stereo not working, and slidind doors either. need fuse diagram
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Alpine TDA 7563 loses presets when vehicle is
You don´t connect correctly the wire for the constant power suply that´s why the memories don´t stand still,always be a yellow one you need to connect to a direct power suply,good luck
Mar 14, 2009 | Car Audio & Video
I have a 1999 Audi A6.
Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
Mar 02, 2009 | 1999 Audi A6
XM Direct 2
On the adapter cable if there is a separate cable for power connect the positive directly to battery power as opposed to ignition. The memory resides on the xmdirect2 module not on the head unit.
Oct 04, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Switching the ignition off loses the preset stations
the red wire and yellow wires are crossed simple fix once radio is off
Sep 28, 2008 | Nakamichi CD-35z CD Changer
Sony CDX-MP40 CD Player Logo
76 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
