Question about Bosch BSG71360UC Bagged Canister Vacuum
I have a Bosch Elector Duo Hepa, BSG71360UC/07. I'm trying to replace the rectangular-shaped part with the carpet brush that attaches to the bottom of the wand. Where can I find this part?
2 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: I am trying to find a replacement wheel (caster)
Hi There,
The casters for your Bosch are unfortunately sold as an entire assembly with all 3 wheels included when you purchase the part. We don't yet have this part on our website, but I did check and my parts distributor does have these in stock and ready to ship.
Here's a parts diagram for your machine that will identify all the parts, and part numbers on your machine. Please feel free to contact us if you'd like to go ahead and place an order.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bosch-bsg71360-parts-diagram.pdf
Chris Jones
GoVacuum.com
Posted on Apr 24, 2010
Lack of suction dyson upright vacuum
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Sep 01, 2014 | Dyson Vacuums
My dyson 07 has no suction
Aug 06, 2014 | Vacuums
Plenty suction from wand, but when you tilt back to vacum no suction at base but brushes are turning
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad. ....
Dec 30, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Rubber strip on sole plate?
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to cleanicon1.png the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Dec 19, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction near brush
Mar 03, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vac cleaner doesn't pick up.
Jan 13, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I am trying to find a replacement wheel (caster) for a Bosch BSG71360UC vacuum. Can you tell me where I can get one?
Hi There,
Chris Jones
GoVacuum.com
Apr 24, 2010 | Bosch BSG71360UC Bagged Canister Vacuum
Bosch BSG71360UC Bagged Canister Vacuum Logo
57 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
