Question about Mantis 2-Cycle Tiller
The tines won't turn when on the ground - Mantis 2-Cycle Tiller
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Troy bult junior has new tines , runs to fast...
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
May 19, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
THE TINES WON`T TURN, THE MOTER WORKS THE TINES WON`T TURN
SOUNS LIKE SOME THING CAME LOOSE IN SIDE THE TRANS
Oct 01, 2009 | Craftsman Garden
Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Apr 09, 2009 | Ariens Garden
Mantis 2-Cycle Tiller Logo
18 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
