Question about Hunter 56 In. Brushed Nickel Ergonomic Ceiling Fan w/Remote & Light Kit
How ca nI get the remote and the receiver for my model 20171 hunter ergonomic ceiling fan?
  • 436 Answers
Here is a link to the parts list with Hunters part #'s for remote and reciever.
http://www.hunterfan.com/uploadedFiles/Support/Owners_Manuals_and_Parts_Guide/98000-01-961.pdf
You'll need to contact Hunter at this link
http://www.hunterfan.com/Support/Contact-Us/
Good luck and Thanks
Please rate FIXYA :)
Posted on Apr 06, 2011
Fan will not work, but light will. it is model # 21871a-420. the remote will not work either function. there is power at the box. i purchased a new Hunter universal remote model # 27227 and the wiring is...
You have to get the correct receiver for that fan. There's no such thing as a universal remote,no matter what it says on the box. Call 1-888-830-1326 and you can order your correct part.
Sep 04, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
I need to purchase a Hunter ceiling fan receiver. The receiver model # is 85069-060.
hunter technical support number is-- 1-888-830-1326 call this number and they should be able to help. good-day ! just tell them you need a new receiver, and give them the model number of the receiver and the fan model number.
Aug 25, 2011 | Hunter Ceiling Fan Remote Receiver...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
I recently purchased a Hunter Ergonomic 56 in. Ceiling Fan Model # 20171 and it turns on or off sporadically and/or the fan will just start. Is there a way to fix this so that I do not have to take it all...
If there is no remote control for this fan, at first thought I would think that one of the connections in the ceiling box that the fan is attached to has a problem. In my experience, the ceiling fan wire is smaller than the wires in the ceiling box. This can make it difficult for the screw type of wire connector to grip the wires in the connection and make a solid connection. I would, turn the power off to that box (circuit breaker) and take the cover plate off the box. Then take the wires individually that come from the fan and pull them 1 by 1 and see if one of these wires comes easily out of the connector. Gently pull these wires. If one or more come out, then re make the connection (you can strip the insulation for a full 1 inch, of the fan wire, double the wire over on itself so that you have 1/2 inch of wire. Try to wrap this around the ceiling box wire that it is to be connected to and install the twist plastic wire connector and twist till snug. Do not over tighten or you will have to get a new connector and remake the connection. The reason the fan may turn on and off is because of a loose connection that looks good, but electrically is not good. The wires connect, heat up a little, break connection, cool down, make connection, heat up a little . . . and you get the picture. Hope this helps.
Nov 28, 2010 | Hunter Dryers
Bought a display hunter 20171 Ergonomics C Fan. The wires were cut short, remote control receiver not included.
have no choice but to buy the original receiver through hunter - not a replacement from HD or Lowes - it will not work.
Nov 27, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
We thought our Hunter Ergonomic remote controlled fans were haunted. One or the other just sort of comes on with no warning or prompting. Is there a way to make them just work from the light switch? They...
Most likely the remote problem is some kind of radio frequency interference. If the main problem is that they turn on when you don't want them on, then you could rewire or just put an extra switch that would turn off the power to the fan completetely. Then you would turn that switch on and use the remote only when you wanted it to run. This would be an extra step, but it would save you buying another fan.
You also might contact Hunter and see if they could send you a regular switch.
Oct 19, 2009 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hunter 56 In. Brushed Nickel Ergonomic Ceiling Fan w/Remote & Light Kit Logo
711 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
