Question about MSI R5450-MD1GD3H/LP RADEON HD 5450, (1 GB) 128-bit DDR3 PCI Express 2 0 x16 HDCP Ready Low Profile Vide Video Card
Need pin arrangement and voltages for the fan connector on this PCB. Please, if someone have those give a hint.
    Problem Solver:
  • 13 Answers
Use a multimeter. Make sure it is set to dc volts. If it has a voltage scale, set it to the 20 volt scale.
Power up your card in the computer only for a few seconds, while you take the reading. You don't want to make your card's heatsink too hot without the fan going.
When it's powered up, hold a multimeter's probes on the fan's pin header pins(one on each pin), be carefull not to short the two pins together.
The meter will give you the voltage reading.
If you get a positive voltage reading, the red probe will be on the positive pin.
If you get a negative voltage reading, the black probe will be the positive pin.
Posted on Apr 08, 2011
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred
the .4 points to the formatter fan (F1) is bad.
Connector J1004. Voltage should be 24 VDC between pins 1 & 3.
If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
May 01, 2014 | HP LaserJet 4600 Printer
Ir400 fan numbers
II. FANS
A. Arrangement and Functions
Feeder fan
Fixing assembly heat discharge
fan 1***
fan 2 ***
Laser driver cooling fan
Laser scanner motor cooling fan 1
Laser scanner motor cooling fan 2
Cleaner heat discharge fan
System cooling fan
Reversing guide cooling fan
Low-voltage power cooling fan 1
Low-voltage power cooling fan 2
Reader cooling fan 1
Reader cooling fan 2
Drum cartridge cooling fan 1
Drum cartridge cooling fan 2
Drum cartridge cooling fan 3
DC controller PCB cooling fan
Scanner motor cooling fan
Function
Draws copy paper to the feeding
belt. Helps feeding.
Discharges heat from around the
fixing assembly.
Cools the laser driver PCB.
Cools the laser scanner motor.
• Cools the laser scanner motor.
• Insulates the drum cartridge
against heat from the fixing
assembly.
• Discharges heat from the
drum cleaning assembly and
fixing assembly.
• Discharges heat from the DC
controller PCB.
composite power supply and the
DC controller PCB.
Prevents curling of paper.
Discharges heat from the lowvoltage
power supply.
Cools the reader (image processor
PCB, laser driver PCB).
Cools the drum cartridge.
Cools the DC controller PCB.
Cools the scanner motor.
Aug 28, 2012 | Canon imageRUNNER 400S Copier
E 550
Check the voltage at connector J1 on the Sorter Controller pcb. 24V is supplied through the controller board and can be measured on J1 pin 2. This voltage goes to the Door Switch (MSW3) and returns on J1 pin 1. If 24V is not present on pin 2, it is possible that the Sorter Controller is bad.
Mar 06, 2012 | Canon NP 6085 Copier
I got an error message 57.01 on my printer. how do i solve this problem
A printer fan error has occurred.(Delivery fan)
J1033 - Measure pins 4 and 6 for delivery fan
1. Turn the printer off then on.
2. Reconnect the connector J1004 on the DC controller PCB.
3. Immediately after starting the print operation, measure the voltage between the appropriate pins on the connector. If the voltage changes from 0 V to 24 V, replace the affected fan.
Aug 11, 2011 | HP Hewlett Packard LaserJet 4700dn Printer
Hp laserjet 4700dnit displayed 57.04 error.i have restarted but no response....what can i do
57.04
3. Immediately after starting the print operation, measure the voltage between the appropriate pins on the connector. If the voltage changes from 0 V to 24 V, replace the affected fan.(Cartridge fan= Fan 2)
Connector J1033 - Measure pins 1 and 3 for cartridge fan
Jul 27, 2011 | HP LaserJet color laser printer
Cannon-3300 Copier Error code E000-0000 rectify the problem
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Jan 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
I HAVE A CANON IR 3300 MACHINE I HAVE ERROR E00000-000
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Sep 25, 2010 | Office Equipment & Supplies
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Copier copies only One page and then produces error message E05-60. Please help me in this regard,
E5-60 is Low Voltage Power Supply Cooling Fan. Check the connectors. Could possibly be bad fan, DRV PCB, SPC PCB, or LVPS PCB.
Mar 20, 2009 | Panasonic Office Equipment & Supplies
Extra wire /fan 3pin hole 1wire where to plug in X 2 fans
If your cpu fan has a 4 pin connector & your mb has a 3 pin you can still use it. Just leave one pin exposed. The extra pin is for a speed control sensor that not all mb's support. The chassis fan has a different connector on the board marked "cha fan". This one is a 3 pin connector. Most of the asus boards have 1 of these. If you wish to run more than one you can either buy a "y" adapter that allows you to connect 2 fans to 1, you could use an extra 4 pin molex to power an extra fan but that would give you no control over the fan, or you could buy a fan controller and hook all your extra fans to it. Hope this helps & please take a moment to rate my solution fixya. Thanks.
Feb 14, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
MSI R5450-MD1GD3H/LP RADEON HD 5450, (1 GB) 128-bit DDR3 PCI Express 2 0 x16 HDCP Ready Low Profile Vide Video Card Logo
251 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
