Question about Sony MDS-B5 Mini Disc Player
Sony MDS-B6P Mini Disc Player doesn't read the disc. Drive motor not turning motor is good. The problem is on the board under the loading mechanism. I swapped boards with another machine and it reads fine. The board is no longer available from Sony.
  • larry_pauley Apr 06, 2011
    Thank you guru68. I just found a service manual which will be a great help.
    Sergeant:
  • 347 Answers
Hello larry_pauley!
please check voltages of motor drive circuit (especially driving transistor), if you still have the working board then you can compare between.
regards
Posted on Apr 06, 2011
I can not load disc. The display blinks IIC STOP
1) A good first step would be leaving the unit unplugged from power for a few days and see if it resets anything.
2) READ YOUR OWNERS MANUAL.
3) Buy another one.
Jan 28, 2014 | Sony MDS-E10 Mini Disc Player
Disc ejected and then retracted.
Check on the web for the fix. Many people had an issue with the Sony MDS-JE500 series MD units as the little lever switch that indicates that a disc is loaded goes bonkers and it might be as simple as 'adding' a non-sticky item to the lever. Do a Google search for 'mini disc switch fix'. Good luck.
Jan 25, 2014 | Sony MDS-JE520 Mini Disc Player
MDS-E10 will not eject disc
The lower end mechanism were full of problems after about a year of use. The unit needs to go to an appropriate Technician- NOT Sony as they will just replace the mechanism if they even work on it and it will be the same cost of a new unit. The mechanism you have needs lubrication and a limiting resistor placed in line with motor to not break plastic parts.
Jan 27, 2013 | Sony MDS-E10 Mini Disc Player
Any disc inserted just gets ejected
Either the loading is not completing of the mechanism or the laser pickup lens is dirty.
Dec 05, 2012 | Sony Vintage Mds-101 Compact Chassis Mini...
Sony mds-je520 on stand by led on bur cant tern on player
Make sure the "TIMER" "Rec"/"off"/"Play" switch is set to "OFF".
Then press power, and you should be in business as soon as it read the TOC on the disc. Without any disc inserted, it should go straight to being ready.
Apr 27, 2010 | Sony MDS-JE520 Mini Disc Player
I have two rack mountable minidisc players can any one in the world fix these things(frustrated).An MDS-E 12 & an MDS -E 10.One just fell over backward from the ground in a wooden rack. The other electric...
I have repaired a number of these over the years, the main problem is usually the loading mechanism or the optics. Neither is cheap. Where are you located?
Dan
Jan 23, 2009 | Sony MDS-E12 Mini Disc Player
Sony MDS-E10 has been dropped. need schematics to solve problem.
Your service shop would need to purchase the service manual (if available). The problem here is that without seeing the unit, I can;t tell you whether the optics are bad or the tracking head is bad or the loading mechanism is defective. None of those options are cheap. Let me look into this a bit and see what I can find. I will try to get you part numbers at least with costs.
Dan
Nov 25, 2008 | Sony MDS-E10 Mini Disc Player
MDS-JE320
The loading mechanism needs to be repaired or replaced. This is a common fault. Unfortunately, this is not a really cheap fix. Usually the loading carriage needs to be replaced at a cost of about $40 or so/
Dan
Nov 10, 2008 | Sony MDS-JE520 Mini Disc Player
Sony MDS-B5 Mini Disc Player Logo
258 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
