Question about Presto 05460 ProFry Deep Fryer
I filled it with oil. plugged it in and the light does not come on and it does not appear to be heating.
Over heating and oil light keeps comming on
maybe you should climb under it and take a good look.... more things than a thermostat can cause overheating. water pumps bad impellers worn off, plugged radiator bad fan... even the lack of oil can cause overheating
Feb 26, 2018 | 1986 Suzuki Samurai
My Comfort Zone Oil filled CZ7007J Radiator is not heating, it was working just fine when I turned it off, but when I turned it back on, no lights, no heat, like it's getting no power. Bought it
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Dec 30, 2017 | Comfort Zone CZ7007 Oil Filled Electric...
My lakewood oil filled heater model 5600/7 just stopped working. It won't turn on..no lights. There is no history of tipping over.
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Apr 06, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Heater does not heat when turned on. indicator light stays red
check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Jan 30, 2010 | Honeywell HZ-710 Oil Filled Radiator...
Bought heater at a yard sale & says oil filled heater but dont know how or where to fill??
The heater should be per filled with oil and sealed allyou should have to do is plug it in and waite about 15 or 20 min for the oil to heat up
Dec 01, 2009 | Heating & Cooling
Radiator
fill your radiator up, let the vehicle warm up and then shut the engine off. Look for the leak it could be a number of things check hoses, radiator, or the heator core inside the vehicle a strong flashlite and small adjustable mirror helps. Other items to check are waterpump, engine block freeze plugs, also check your oil if it appears milky you could have a blown head gasket.
Feb 12, 2009 | 1994 Dodge Grand Caravan
Won't heat
Is there a thermostat? where are you from and do you understand electrics? do you have a volt meter?
Dec 22, 2007 | Pelonis WM-HO202C Oil Filled Radiator...
Presto 05460 ProFry Deep Fryer Logo
56 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
