I have a canon printer i250, the start button is flashing and it will not print, there is a message coming up - the used ink tank is full, cancel printing and turn printer off and then back on. I have done that and it still does not work, please email me - etylke@yahoo.co.uk - thank you very much
  • drmacuk Mar 05, 2009
    Same problem but when I open the front of the unit the cartridges remain hidden and cannot be removed.
  • 4 Answers
See my solution above on same problem...
Posted on Mar 02, 2009
  • 37 Answers
Please remove the catridges once and cleaned with soft cloth in the connection surface i think this will solve your problem
Regards
T.Boopathy
Posted on Aug 06, 2008
Not printing, flashing amber-green light. Message says waste tanks are full....................HELP
Hi there! Follow those steps: i250, i350 and i000 series
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
This method will work only whilst the printer's connected to power. Turning off and on at the switch will keep it, but unplugging it from the power will reset it, which means you'll have to do this again: What this does is temporarily reset the printer, but also stops it from doing headcleans everytime you open the door to switch print heads or ink tanks.
Thaky for using Fixya.com
Nov 24, 2010 | Canon i350 InkJet Printer
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Error code on my ix4000 reads 5C00
Canon has a decent trouble shooting guide for this model:
http://www.usa.canon.com/consumer/contro...
Click on the Step-by-Step Troubleshooting link under Tech Support
Unfortunately it does not give any possible solutions for blinking lights.
The user guide on the other hand does.
You can download this under Downloads -> Product / Software Manuals
Here is a summary of what the flashing lights could mean:
See Paper Jams
Six flashes: No print head installed
Install a print head.
Seven flashes: Print head is defective
Contact the Customer Care Center.
Ink used for cleaning is absorbed in the waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact the Customer Care Center as soon as possible. Once the waste ink absorber becomes completely full, printing will no longer be possible.
Nine flashes: Ink tank is not installed properly
Open the print head cover and press the button of the ink tank and reinstall the ink tank properly.
Ten flashes: Battery level is low
Charge the battery. For details on how to charge the battery, refer to the manual supplied with the battery.
Eleven flashes: A specified period of time has lapsed without receiving a response from the digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME/CANCEL button and reconnect the cable.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use digital cameras or digital video camcorders that are compatible with this printer.
POWER lamp flashes alternate green and orange:
An error that requires contacting the Customer Care Center may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it about 10 minutes.
If the problem remains, contact the Customer Care Center.
Jun 19, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
See Paper Jams
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
"used ink tank is full"???
OK, Boys and Girls...here finally is the complete answer to the problem of the waste ink tank counter reset for Canon i250 and i350 printers.
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...It did for me.
You May Thank Me NOW!!!!
I must say...I went into the "GUTS" of the beast and cleaned out the PADS (they are actually vacuum pads that the INK is sucked through during a HEAD cleaning) a very messy undertaking.
I'm not sure how much life this will add to your printer.
Good Luck
Aug 23, 2007 | Canon i350 InkJet Printer
131 people viewed this question
k24674
