Three inside the washer, one for soap, then downey and then bleach. Problem is I don't know which is for the downey and which one is for the bleach
  • 456 Answers
Hi. downey would normally be the smallest section in the middle.
Posted on Apr 06, 2011
Water Drains from underneath the soap dispenser when I start machine.
This could be an easy fix. Lift out the whole tray and wash in really warm water in your sink and wipe out anything you see inside the machine. It could be a lump of Downey or soap caught up. Good Luck.
Dec 15, 2014 | Kenmore HE2 Plus Front Load Washer
I just moved into an apartment and have a Bosch front load washer and dryer. I'm not sure if I'm putting the soap, bleach and fabric softener in the correct trays . There are three slots and I
I am not sure of the dispenser trays but if the clothes are taking to long to dry and are still damp, check the vent hose and the duct work going out the apartment for lint buildup.
Oct 14, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Samsung wf410 musty smell clothas
you ahve to treat this with bleach first and try some cleaner they have a few on the market for this, then spray inside of door with bleach or window cleaner it molding inside, most people leave the door cracked open and the soap dispensor open to let the washer dry out during washes, inst this the Pitts, Matt
Jun 12, 2012 | Samsung WF410ANR Washer
The smell of my laundry
Try putting one more sheet in the dryer as far as the Tide with Downey it`s propbably getting rinsed out when your washer goes through the rinse cycle.
Feb 20, 2010 | Whirlpool Dryers
Cannot get it to uptake the bleach for spraying Dewalt pressure washer 3100 psi
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Nov 21, 2009 | Dewalt Garden
Where does the detergent go on the ez3701cee, in compartment A or C?
Detergent Dispenser
The detergent dispenser has 3 compartments,
marked A, B, and C.
A. Pre-wash detergent
B. Wash Detergent, Bleach (e.g. Clorox®)
C. Fabric softener (e.g. Downey®)
Note: The Bleach must be filled into “B”
compartment.
Jul 07, 2009 | Equator EZ 3710 CEE / W Ventless...
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
Kenmore elite washer smells
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap.
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3t washer
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
