Question about HP Photosmart C7280 Printer
One more try. My C7280 printer makes terrible noises when it pulls the paper through for printing. I have tried reinserting the back part where I clear paper jams, but it does not help. Also this printer has a paper jamming problem that other HP printers I've owned never had. It jams about every 20th page or so.
  • HP Master
  • 1,591 Answers
Without hearing the noise or having a description other than "horrible", I'd say probably the pickup clutch or the gears that turn it are having an issue and need to be replaced.
To my knowledge you can't order either of these parts (it's not like the good old days) but at least it's replacement is on sale at the moment for $79.99 from HP.COM (probably what you'd have to pay to get yours fixed at a shop).
the D110A is the least expensive photosmart all in one at the moment.
Keep your 7280 as a scanner though if the ADF (auto document feeder) is important to you when scanning, the D110A is flatbed only.
Posted on Apr 06, 2011
Pump motor stalls in my HP printer
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Oct 14, 2014 | HP Photosmart C7280 All-in-One Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
When i am printing it make a wierd clicking noise, i have replaced the ink in it, and it still won't print properly, it only prints 1/2 lines. I have cleaned the cartridge. Please help
Sounds like something is rubbing somewhere that shouldn't be, so if it continues there is certainly some damage being done.The vacuum suction can sometimes make terrible noise, esp. on rc-papers like Premium Luster et al.
Try to lower "Paper Suction" in the print driver.
Feb 16, 2011 | Office Equipment & Supplies
My HP C6280 says that there is a paper jam. I
dear sir this problem is your printer macanical
please open printer cover and chack clought unit spring tension
Aug 12, 2009 | HP Photosmart C6280 Printer
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
I have installed the HP Photosmart C7280 All-in-One and tried to print an article off the computer. I have paper loaded in the tray-I get a message Out of Paper. Load paper face down in Main Tray. What's...
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Apr 11, 2008 | Office Equipment & Supplies
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
HP Photosmart C7280 Printer Logo
216 people viewed this question
Seeker5211
Seeker5211
