Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
How do you put the soultion in and how do you use it
  • 436 Answers
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Posted on Apr 06, 2011
I SEEM TO BE CONFUSED AS TO WHAT SIDE THE WATER GOES. ALSO WHAT SOLUTION OF CLEANER SHOULD I USE. MY PRODUCT IS THE BISSELL LITTLE GREEN.
Water goes on the left side and the collection tank is on the right. I suggest the Bissell soultion it runs about $10
May 07, 2011 | Bissell Vacuums
How to put a Kirby Vacuum belt back on New belt seems too short
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Jan 27, 2010 | Kirby G5 Bagged Upright Vacuum
Water and cleaning fluid not coming out
water head pluged use tooth brush and hot hot water ,on bottem of vacc find water heads brush until clean
May 06, 2009 | Bissell Powersteamer 1694 Upright Vacuum
Self propel belt is too tight to put back on
the best way to install it is to put it on the motor shaft first and then to start putting it on the large pulley at the top and roll it on these belts can be hard to put on.
Jan 05, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Cleaning solution just flows out
Make sure the cap and the inner valve is seated tightly. There should be a black rubber gasket to help seal the cap and valve. A quick test is to fill the cleaning soultion tank with water (so not to waste the cleaning solution) turn it over and see if it leaks. If not then the problem would be where the tank sits in the unit. Make sure there is no debris in the unit where the tank sits.
good luck
D...
Sep 28, 2008 | Bissell 1699 ProHeat Clear View Upright...
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Can't get water to spray out of the hand tool nozzle
When you attach the main suction hose to the front of the machine, you also have to connect the soultion hose to a valve located on the side of the machine. When the machine is running, take a small screwdriver and depress the centre of this valve. You should get a spray of water out of the valve which will confirm the valve and pump is working. Now, connect the small solution hose, making sure you push it on all the way. When you pull the trigger on the handle of the hose, you should get spray. If it does not, you may have a plugged nozzle sprayer.
Feb 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Smelled like rubber burning
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and put the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Dec 14, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell laminate floor cleaner wet vac and flips to dry vac
You just need to replace the cap and valve part # 2036919, You should be able to order the part thru Bissell.com, or they will tell you who you can call close to you.
Dec 06, 2007 | Vacuums
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
189 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
