Question about Kenmore Sewing Machines
The clutch on my kenmore 1310 won't disengage when i go to wind the bobbin. i turn the clutch knob toward me, and the clutch is still engaged.the machine needle continues to operate while i wind the bobbin
    Scholar:
  • 89 Answers
May be one of two problems.
1st you should be able to turn the nob about 90-120 degrees. Not a full turn.
If this is not the case follow these steps.
Turn the small screw on the nob about 2 full turns
Carefully turn the nob all the way off.
Inside there is a round part with 3 small prongs on it.
spin that 180 degree and put everything back together.
2nd your clutch is gummed up
You will need to remove the handwheel and motor belt for this.
Remove the nob, small 3 prong part, and motor belt.
Pull the handwheel off (it may be stuck on and hard to get off).
Clean inside the handwheel and the machine main shaft.
Lubricate the Main shaft and put handwheel back on.
When you put the small 3 prong part back on it needs to have the prongs sticking away from the machine.
Hope this fixes your machine
Posted on Apr 06, 2011
Trying to rewind bobbin machine starts beeping and stops
Is the bobbin pushed over to engage the stop
Oct 01, 2017 | Sewing Machines
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
Disengage clutch kenmore sewing machine
http://www.shopyourway.com/manuals/9253 is the manual. Turn the center of the handwheel knob toward to you to disengage the clutch.
Dec 26, 2013 | Kenmore Sewing Machines
Elna supermatic bobbin winder will not spin
is clutch disengaged? inner wheel in flywheel, hold flywheel and turn inner knob towards you to loosen. put bobbin on spindle and move to right to wind. if youve done this already and no joy then bobbin winder tyre may have perished. try www.sewingpartsonline.com to buy new one
Oct 13, 2011 | Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
My kenmore sewing machine won't wind the bobbin on. The motor runs but the bobbin is not engaged.
Not all models are the same.
You will have to refer to the manual to see what needs to be engaged or disengaged.
On some machines, this is loosening the center knob on the handwheel and moving the bobbin pin to the right or the winding knob to the left.
There are threading/bobbin winding guides sewusa.com where you may find your model or one that is similar.
Mar 21, 2010 | Kenmore Sewing Machines
Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Sep 01, 2008 | Sewing Machines
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
432 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
