Question about Hampton Bay 73554 Antigua Ceiling Fan
My antigua ceiling fan made a popping noise and sparked when I turned on the switch and now it will not work. I think the motor blew up. What can I do?
Pranavendra
  • 16 Answers
SOURCE: 42" ceiling fan
1. Try to rotate it by free hand and see it is free machanically. If not, it ball-bearing/bush should require lubrication or replacement.(Note at this satage there should be no electric supply to fan.)
2.If it is free, rotate it fast by hand, then immediately switch it on.
a)If it continue to rotate, then there is fault in capacitor.Replace it.
b)If not, ask me.
Posted on Nov 29, 2007
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Posted on Apr 03, 2008
SOURCE: I'm tring to find a light globe for may antigua
I am thinking of buying this fan, but do not want to use the light. Are you still looking for a light globe?
Posted on Mar 25, 2009
  • 10865 Answers
SOURCE: new ceiling fan . Motor has humming noise.
Return it while it is still under warranty.
Posted on May 16, 2009
Two days ago my hampton bay fan made 4 or 5 popping sounds, sparked and smoked for about 3 seconds. but works perfectly do i clean it, and carrry on or do i have to worry about it?
hi.
DO NOT USE THIS FAN. disconnect if possible.
any spark, smoke and popping noises from any electrical items MUST be treated as highly suspect and a possible fire risk, until professionally tested and given the all clear.
it may just be a few bits of dust burning off, but it MUST be checked before you can assume it is safe.
sparks and smoke with a little dust or grease can cause a fire.
i AM trying to frighten you into doing something rapidly, as this could be a serious fire risk, and must be considered dangerous until tested and proven to be safe.
i would not be doing my job responsibly if i did not make this point absolutely clear
Jun 14, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Where can i order a new motor for this model
Check this response from 2008 for same model fan.
By resorrowsr on Oct 26, 2008
Fan stopped Turning - Removed fan to check all the connections. All the connections were good. When you turn the fan on, you can hear a humming sound. If you take off the blades you can spin the motor and it will work, but will not turn on it's own.
    • resorrowsr
    • 2 years ago
    I called Home Depot customer service. I had my receipt, so they gave me store credit for the full purchase. Since I have two fans, they wanted to know if I wanted to replace both fans. I told them one was still working fine, so I only replaced one. My problem was the transformer. You could see where it had overheated and melted.
http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=Hampton+Bay+73554+Antigua+Ceiling+Fan&langId=-1&storeId=10051&catalogId=10053
Jan 30, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
How do you reverse the blades when there is no switch on the fan itself.
there should be a switch on the motor try taking of the cover (make sure power turned of )
Jan 02, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Turned on fan after not using it all winter and motor is very loud
Oil it. Oil might have leaked all winter. I think you should fix your leak.
Apr 03, 2010 | Hampton Bay 73554 Antigua Ceiling Fan
I'm tring to find a light globe for may antigua ceiling fan mine broke when tring to take down form ceiling. where can i find one?
Feb 28, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 73554 (56-ANT) from Home Depot
You need a new motor, are you still in warranty?
Oct 26, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Fan motor does not turn
FIRSTLY HOW MANY WIRES ARE COMING OUT THE FAN MOTOR AND WHAT COLOUR DO YOU GUYS USE AS LIVE AND NETURAL IN YOUR COUNTRY.
MOHAMED
Sep 19, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
HELP! WIRING...LIGHTS DO NOT WORK
Yes, the blue wire is for the light. Just connect it to the hot wire (black).
Jul 15, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Ceiling fan power
It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 73554 Antigua Ceiling Fan Logo
246 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
