Question about Acer Aspire 4720 Notebook
Hey, I recently formatted my acer Aspire 4720z(including the RECOVERY partition). Now i try to install a new OS, it doesn't load, it gets to a point and it gives me an error message with code: 0x8007045D. Pls, i want someone to help me on how i can get to successfully install my desired Windows 7. *I did a clean format of both partitions, so nothing is left. Thanks.
  • Bill Castor Apr 06, 2011
    Solution didnt work. . .
    I have tried three different windows 7 ISO CD's.
    Also attempted vista and XP, none worked. . :(
  • 2,632 Answers
Welcome to Fixya. Windows cannot install required files. Make sure all files required for installation are available and restart in the installation. Error code: 0x8007045D
You are receiving this error because Setup is unable to validate the Windows image file; it believes it to be corrupt. There are a number of things that can cause this but most often it's due to bad media. Assuming that this ISO you downloaded has a valid CRC check, you should try to :
  • reburn media at a very slow rate
  • use the best media that you can find
  • avoid ISO mounting utilities that mount the image as a removable drive
If you download the Windows 7 Operating System I suggest re-downloading it from microsoft and try again.
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 06, 2011
  • Rofel Lantican
    Rofel Lantican Apr 06, 2011
    Have you tried to use the CD installer on other machines and see if you will have the same error. So that we can check if this is a problem with the CDROm of your acer machine
  • Rofel Lantican
    it's possible that the physical device (DVD) is causing the error. We have seen this failure in the past although a bad burn is more common.
Hi i have an acer aspire m5100 have backed up the 500gb hard drive and needed to change hard drives but when i restored both partitions and tried to do an erecovery it doesn't work didn't clone...
Greetings,
As you can see from the figure, recovery partition can be seen in the Disk Management but it can't be accessed. unless you give or assign a lettter to that partition using Diskpart and run as an admin. you have to clone the original hard drive from your Laptop to have a recovery menu. you can create your own recovery.
Jul 08, 2011 | Acer Aspire 5610-4648 Notebook
I cant start may laptop after formatting c-drive
If you took the hdd out and format it ..it will need to reinstall the operation system ..If you tried to install the operation system ..but now it says there is no operation system ..you need to reinstall it ..Anyway ..if it starts ..but not boot to windows..Just reinstall the operation system using a boo-table cd ..with the OS ..or the recovery partition on it ..by pressing the F12 ..and choose recovery partition ..(boot from ) if it has one ..it may be damaged when you tried to format ...
Remember to format means erase and form the memory units again ..and not installing ..reinstalling is another issue ..and when you do it ..it gives you the possibility to completely format a partition ..including C in our case..so that you are sure you end up with a clean Operation system ..
Sep 01, 2010 | Acer Aspire 4520-5803 Laptop
I've acer aspire 4720z from few days i got virus.cmd now i cann't entered because windows ask for aspire 4720z password but i didn't set it before , i'm trying to format it but i cann't enter to safe mode,...
you can format it using clean install just insert the Windows OS CD then go to bios set the cdrom as the First boot device then press the a key on the boot screen wait until it ask you to select a drive to install the WIndows OS format the drive using NTFS, you can also set a partition on the drive for backing up purposes. Select C: drive install WIndows at the middle of the installation you need to enter the Serial Key and the timezone etc etc.
Jul 30, 2010 | Acer Aspire 4720 Notebook
I have an acer aspire 5515 laptop and it wont load at all after i restarted it. Its comes up with the microsoft corporation thing with the loading bar but its not loading. I had this problem before when it...
you can try to reinstall Win in another drive on the machine....i.e.. if you have a partition on the harddisk then you can try to install Win in a drive other than the usual C: drive in which you current OS is loaded...then when u boot the machine after installing the OS in say D or E then chose the OS to load when it give the optin on the DOS sceeen...by this you can recover all you critical files and then do a clean install again after formating you entire HD in C: drive....
all the best
visit my site for more info on formating and installing OS
www.sureshayyar.110mb.com
Jul 10, 2010 | Acer Computers & Internet
Acer 5520 restore failed 0xa000000e
I got it to work by deleting all the partitions on my drive (I first loaded xp, loaded system commander 9, and used that to delete all the partitions.)
Then while booting from the recovery cd, holding down alt-f10, the recovery dialog said it was partitioning the drive. (I didn't see this before, even if I partitioned the drive like it came from the factory.)
Then the rest of the recovery worked.
Feb 11, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 3680 problem (anyone help plese?)
if you haven't delete the recovery partition, you can reload the OS using alt+F10.
during boot (after acer logo), press alt+F10, it will guide you to reload your OS.
if your recovery partition is corrupt, you should call acer call center to get the cd or you can buy cd from microsoft
Jul 05, 2008 | Acer Aspire 3680 Laptop
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 4720 Notebook Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
