Question about Visual Land V-Bop MP3 Player
I have a Daze 3-n-1 was curious if it has a shuffle on it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
SHUFFLE PROBLEM
The playing mechanism has failed.
Nov 10, 2013 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
My ipod shuffle will play my downloaded songs on my computer but not with earphones?
Make sure the earphone or headphone connector is pushed in all the way.
â Make sure the volume is adjusted properly. A volume limit might be set.
To remove the volume limit:
1 Connect iPod shuffle to your computer.
2 In iTunes, select iPod shuffle in the Source pane.
3 Click the Settings tab.
4 Deselect “Limit maximum volume.”
Enter the password, if required
Mar 07, 2010 | Apple iPod shuffle MP3 Player
How do I turn the shuffle off?? I go to settings, choose music options, choose shuffle and highlight "on" and nothing I hit makes it change to "off". Help!!
For the Sansa Fuze, the selection Shuffle Mode is correct, just like you told:
In Main Menu > Music > Submenu > Music Options > Shuffle Mode:
1. Select Shuffle.
2. Use thumbwheel to choose Shuffle on or Shuffle off.
(to play songs in random order, set Shuffle to ON).
3. Press Select to change the Shuffle mode.
See page 9 (=page 6) of the manual in pdf format for the Sansa Fuze:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Thumbwheel: 5
Select button: 9
Jan 07, 2010 | SanDisk Sansa Fuse MP3 Player
I cannot find a solution for Puzzle 98
The puzzle is fairly straightforward and the hints give you most of the solution, which can be seen here
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle098.html
As pointed out in the walkthrough, note that the cards need to be placed on the card shaped spaces, not merely shuffled around at the bottom
Oct 03, 2009 | Nintendo Professor Layton & the Curious...
Cards - no. 98
While the three hints in the game basically give you the entire answer, some players have a problem with this by shuffling the cards around at the bottom of the screen instead of placing them on the card shaped spaces (below the blue cards) You can see the solution here if you need it http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle098.html
Jun 04, 2009 | Nintendo Professor Layton & the Curious...
I Pod shuffle (2nd. generation) won't hold a charge
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
software.
You can choose either to update or to restore the iPod shuffle software.
If you choose to update, the software is updated, but your settings and songs are not
affected.
If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
My ipod shuffle is not being recognized by the pc and not chargin
If the shuffle is over 18mth old it might very well be the battery. However do just try a Reinstall of iTunes then an upgrade of the shuffle software if you can connect it. The other alternative if the thing still doesn't connect is that it's the main board or connector itself although these are more unlikely.
A new battery for a shuffle is about $5-10 (£3-6) on eBay and normally comes with instructions and tools.
All the best
Sean
PiDigital
Nov 22, 2008 | Apple iPod shuffle MP3 Player
Green/orange flahing light on IPod and no music.
From Apple.com Support Website. If the front status light on your iPod shuffle blinks orange and green when you press any button, then your iPod shuffle is experiencing some type of error. Try these troubleshooting steps to resolve the problem. To troubleshoot the iPod shuffle error light: 1. Turn off your iPod shuffle 2. Wait a few seconds 3. Turn your iPod shuffle back on again If this does not resolve the problem: 1. Check to make sure there are songs on your iPod shuffle 2. Use iTunes to add songs to iPod shuffle and try again If your iPod shuffle continues to display a blinking orange and green light, use iPod Updater 2005-02-11 or later to restore iPod shuffle, and then add songs with iTunes. If your iPod shuffle still shows a blinking orange and green light after trying all of the above steps, your iPod shuffle may need service. Best of Luck.
Sep 11, 2007 | Apple iPod shuffle MP3 Player
Visual Land V-Bop  MP3 Player Logo
94 people viewed this question
Top Visual Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Ed Mac
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
