Question about Garden
Ahoo.comI have a brother inovvis 4000D when I start to sew ro embroider the upper thread goes down and hooks bobbin thread but it never brings it back up so I am getting a lot of birdsnesting.I have rethreaded needle and bobbin, changed the bobbin caseing cleaned it out several times readjusted the bobbin casen think I didnt put it back in there right I dont now what else to do beside take it in but that is the last thing I want to do if i can do it myself.
3 Suggested Answers
  • 252 Answers
SOURCE: the engine has a miss on the right cylinder that
hi there , pauly46 here
yes it does sound like you have a magnetron coil going o/c when its gets a little tempreture on it .
it would sugest that you also check the grounding wire for that coil for any possible grounding to earth that should not be happening ? then look at replacing that magnetron armature
to get a new armature you will need the model and type codes off the engine ,
think your engine will be a briggs vee twin - this is very important that they be correct
http://www.partstree.com/parts/?lc=briggs_and_stratton&mh=397
here is web site for parts -:
select your model series number from list , then enter, then select the type number from the list
(these must match your model and type codes from your engine )
select alternator / ignition section , then find ref part 333 this is armature
it will have a briggs part number assigned to it
you can select it and add it to your shopping cart and order it on line , from
www.partstree.com
any problems let me know
cheers pauly46
Posted on May 08, 2011
  • 5 Answers
SOURCE: Upper Thread Error
I just posted this under another Brother machine...mine is a se 350 but, might be the same problem!! Hi....I also kept getting the check and rethread upper thread message, I'd sew about 15 stitches and it'd stop. Here's what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slice/cut in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slice/cut in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would've ever thought that it'd be so easy and save me a bunch of money!!! I sure hope this helps someone.
Posted on Jan 07, 2013
Threading sewing machine
For the upper thread, you thread the machine from right to left. Raise the presser foot and turn the hand wheel to get the needle in its highest position. There is a mark on the hand wheel that will be on the top. Place the spool on the pin on the right side of the machine (make sure that the pin is up). Bring the thread to the guide at the back of the machine. The thread goes under and then over the top. Then bring the thread down the right-most slot. Then bring the thread up and through the take-up lever (again it goes from right to left). Bring the thread down to the needle bar thread guide. Hold the thread in your left hand and use your right hand to get it into the guide. Then thread the needle from front to back.
For the bobbin, first make sure that the thread is coming off the bobbin counter-clockwise. Then hold the bobbin down with one finger while you guide the thread through the slit near the 4 o'clock position (using a 12-hour analog clock). Then bring the thread to the left and outside of the bobbin case area and over to the thread cutter.
Brother has the manual and a quick start guide for the CE-4000 on the product support page: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CE4000 . Click on the Manuals and Documents tab. The upper thread threading diagram starts on page 16 of the User's Manual. The direct link to the manual is http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/XC8835821_10K_v_01206-2.pdf . The information for putting in a full bobbin starts on page 14. The pictures will help.
I hope this helps.
Mar 10, 2017 | Brother Office Equipment & Supplies
How to thread a brother xl 2230
Do you need the directions for threading the upper thread or the bobbin? For the top thread, place the spool on the pin (pull it up if needed). Then raise the presser foot with the lever and the needle (with the balance wheel on the side) to their highest point. Now work from the right to the left. Hook the thread on the rear thread guide and bring the thread forward and down to the front thread guide. Bring the thread up and pass it through the Take-Up lever. Bring the thread up and back down so that it falls into the slot. Bring the thread down and pull it behind the guide above the needle. Then thread the needle from front to back. If you have put in the filled bobbin, hold onto the thread and use the balance wheel to bring the needle down and back up. Use the upper thread to pull up the bobbin thread and pull several inches of the thread to the back of the machine.
Brother has the manuals and quick set-up guide on the product support page: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=XL2230#.VRHrpaSFr3g . The quick setup guide, http://www.brother-usa.com/VirData/Content/en-US%5CHAD%5CConsumer%5CQuickSetupGuide%5CQSG_XL_2230_EN_3166.pdf , has very good pictures of threading the machine.
I hope this helps.
Mar 24, 2015 | Brother Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
Jan 13, 2012 | Brother ULT2001
Upper thread will not grab bobbin thread and pull it through
take the bottom plate off where the foot rides and watch the hook as the needle bar goes up and down you will be able to see why. to cure this problem take the plate off where your tension adjustment is because to cure the problem you have to adjust the needle bar either up or down to make the needle meet the hook when the needle is just starting up.
Jan 18, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Upper Thread Error
Oct 22, 2007 | Sewing Machines
Automatic Threading not working
if you damp the end of the thread this seems to cure this
Jan
Leighton buzzard
Jul 02, 2007 | Brother Disney PE-400D Computerized Sewing...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
