Question about Hitachi (DK32DJ-18MW) 18.4 GB Hard Drive
Hi, Il have a hitachi dk32dj-18mw scsi hard disk and lsi bios return "the media format is corrupted...... sense key=02 asc=31 ascq=01" Is there something to do ? Thanks and sorry for my english...
  • 76 Answers
Sorry, but your HDD has come to an end. you may be able to recover some files from the drive.
Posted on Apr 06, 2011
Sony DCR-SR68E was showing error:31:00 and i went on and unplugged the hard drive and then plugged it back in. now its showing error C:13:02 saying overheated cannot access media. help me please
hi,
your HDD is either not connected properly or the connector is gone opposite side, please check it and correct, if the error code is showing again go to menu, manage media, then format disk
Feb 12, 2016 | Sony DCR Video Cameras
Populate SCSI-B connector on SE7520BD2V
Intel Bios update information states these as supported functionality:
1. 8 * DIMMs DDRII-400 2. Intel(R) Xeon(TM) Processor with 667MHz/800MHz system bus speed. 3. Multi-boot support. 4. System Flash BIOS ROM 5. COMA/COMB port 6. CD-ROM boot 7. Floppy port 8. PCI 33/66, PCI-X 66/100/133 mode 1, PCI-E x 4, PCI-E x 8, PCI-X 66/100/133 mode 2 slots 9. ATI* Rage* XL VGA 10. Serial ATA 13. Clear CMOS 14. Legacy Power button 15. ACPI S0/S1/S4/S5 15. Setup screen 16. Summary screen during POST 17. Legacy USB keyboard / mouse / Floppy / CDROM / HD 18. ARM (ATAPI Removable Media) / IRM (IDE Removable Media) 19. Custom CMOS load/save 20. BIOS recovery 21. Intel Platform Security 22. Intel Server Management 23. LSI 53C1030 dual channel SCSI 25. Customer CMOS backup/restore 26. IMT support 27. User Binary feature 28. SERR/MERR detection & logging for runtime 29. Int15 for ABS2.0 30. ACPI SPCR (Serial Port Console Redirection) 31. NMI detection for PERR/SERR 32. Rolling BIOS 33. SOL (Serial On Lan) 34. Multi-disk Recovery Item number 23 is this lsi chip: http://www.lsi.com/downloads/Public/SCSI/LSI53C1030/lsi53c1030_pb.pdf
You should locate that chip on the board, The information in the bios update functionality lists that as being functional; however I'm not certain if they mean you can put that lsi chip on professionally or if its there and you would just need to populate the connector to use it. I'm not sure if a bios update is required, they didn't mention that in any of the actual features added to the update, and they say that if updating the bios doesn't fix something, then you shouldn't attempt to update it anyway.
But a whole other issue is whether or not you should physically solder in a new connector or do you mean populated as in a wire is not plugged into a connector and going to a scsi hard drive
May 19, 2012 | Intel SE7520BD2 Motherboard
Windows 2003 OS installation problem on LSI MegaRAID 320 SCSI CARD so how to install windows. pls advise
use floppydrive to select driver / dump server media & drivers into on folder.use windows unattended cdcreator to create media with drivers
Mar 25, 2011 | LSI Logic MegaRaid SCSI320-4X (320x4128t)...
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
While Booting My Desk top Precision 360 of DELL.I have SeagateST373453LW SCSI Hard disk.At start up disk is recognised but capacity is not. If I am Verifying or Formatting my drive throug Ctrl/A for...
There are a couple of things here..
First I am going to assume this is the LSI card that came with the Dell.
1. Since it is a RAID card, the formatting you are seeing may be referring to the RAID structure. Does the configuration utility ask you what format to be make the drive (i.e FAT, FAT32, NTFS, etc.)? If not, it may be doing that type of format. Also, you did not mention a second drive so the controller may be getting confused. If you have a boot disk/cd rom for the operating system you wish to load, try booting the disk. In a lot of cases, the operating system will format the drive to a particular format.
2. Make sure your controller and drive are not on the same channel. A lot of cards auto assign this but since the Dell has a 2003 date, its worth checking.
3. I've seen drives detected before but not usable. It had to do with the SCSI cable and termination. If this is the SCSI card and hard drive that came with the computer, this may not be an issue (assuming it worked previously).
Nov 02, 2009 | Dell Precision 360 PC Desktop
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Can not install windows server 2003 on Acer Altos G710
Hi! Turn off computer check cable & power cable connection. Windows 2003 Operating System will not support SCSI Drives.
Apr 08, 2009 | Acer Altos G710 Server
Install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
Jul 04, 2008 | Dell PowerEdge 1600SC Server
SCSI BIOS not installed / ML150G2, exchanged mainboard, RAID
hi..
my guess is no but since i haven't dealt with this type of server i'm going to suggest you go to hp.
if you just goto hp.com and search on live chat and a link will come up.. they should be able to help unless it's too old since i'm not sure what generation we are on now..
good luck, hope this helps a little..d
Feb 23, 2008 | Adaptec (2120S) SCSI Controller
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Hitachi (DK32DJ-18MW) 18.4 GB Hard Drive Logo
100 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
