Question about Hansgrohe Plumbing
Dear kind people, we have owned with pleasure the Hansgrohe Interaktiv Higharc Kitchen Faucet for five years and now we have the constant drip when the handle is shut off. I was able to remove the cartridge and inspect it. It looked brand new, with no significant calcium build-up that I could see; Nor did I observe any cracks either. Also I notice that the drip stops when I cut the hot water supply valve with the cold supply still on. My QUESTION is...do I need to buy a new cartridge for $30?
  • 710 Answers
You could try lubricating the O-rings first, then replacing the rings if it is still leaking. Just a little vegetable oil or vaseline will do.
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Posted on Apr 06, 2011
Spray will not convert to full flow stream
Usually the aeratorscreen has to be removed and cleaned.
May 10, 2015 | Hansgrohe Talis S Pull-Down Kitchen Faucet...
How to repair a constant drip on Hansgrohe Talia (hot water handle)
Most likely you will need a replacement cartridge to resolve a constant drip. This model uses the M2/M3 cartridge part number 92730000. It is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Dec 04, 2012 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe 35807801 kitchen faucet leak
On the 35807801 there are generally only two causes of a leak. If the faucet does not seem to shut off and constantly drips it will most likely be the cartridge. This will be part number 92730000. If the faucet is leaking around the sprayer or below the sink the most common cause is the pull out spray hose. This will be part number 88624000. If you need further help locating the parts or a dealer feel free to call Hansgrohe Tech at 1-800-334-0455.
Nov 18, 2012 | Plumbing
I have a Hansgrohe interaktiv shower panel. The shower head keeps dripping. I have had a handyman change the washers and clean the filter. The dripping stops for a week or a month then starts again
After eight years of service it is likely the cartridge has worn out. The Interaktiv shower panels use a ceramic cartridge that do not have seals or gaskets that can be replaced. You will most likely need to purchase a replacement shut off diverter unit through your local dealer or online dealer. If you need help with part numbers feel free to call me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
May 22, 2012 | Home
Faucet drip
This is most likely due to the cartridge being worn out. Feel free to call me at 1-800-334-0455. Press 2 for technical and ask for David. I'll be glad to help.
Apr 10, 2012 | Hansgrohe Plumbing
I have a hansgrohe 06697865 Kitchen faucet with "Spayer" end That drips constantly Where can I buy a kit to repair, and how to manual?
You should contact your hansgrohe customer service hotline found on the installation book. They will help you solve the problem.
Aug 29, 2011 | Hansgrohe 32070821 Talis S Single-Hole...
Constant slow leak
more than likely hot side that is leaking as hot water tends to soften washer...try shutting off hot water angle stop under faucet...if drip stops it the hot water.. try pulling handle off and tightning nut that hold stem in place..
Nov 21, 2010 | Hansgrohe - Lavatory Faucet - Centerset -...
How do I repair a constant drip on Hansgrohe Solarisn?
You will need a replacement cartridge, please give us a call the the below number or email me and we will assist you with this.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Oct 21, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe 06566860 Metro Single Hole Kitchen Faucet periodically makes noise and reverts from needle spray to full spray by itself. Have to press on needle spray indicator on top of sprayhead 4 or 5 times...
make sure the hose under the sink, ( the one that goes to the faucet) has not gotten twisted around anything. sounds like it is losing pressure. it takes steady pressure for the stream to maintain that "needle" spray.
Feb 15, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe kitchen faucet 20 years old
No problem. I need the manual for the 20 year old faucet so I can remove the cap and grease the arm action' The unit is a Hans Grohe vintage 1998.
Sep 23, 2008 | Hansgrohe Plumbing
Plumbing Logo
380 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
