Question about Panasonic KX-T7630 Corded Phone
A red light is showing at the top right of phone
Please could you tell me what it means and how I can switch it off,
Thanks
  • Anonymous Aug 11, 2008
    Have a Panasonic KX-T7633. Same problem of red message light on. Message on phone is "Incoming call: 001". How can I clear it?
    Also, The time showing is wrong. How can I correct it on all phones on system?
  • Anonymous May 22, 2009
    I have the same problem. Incoming call: 001
    Scholar:
  • 108 Answers
The red light is a message light and when it is red it means you have a message either in your voicemail or someone in the office called you and you did not answer so they pressed their message button and it turned on your light. Does your display have any information about messages?
Posted on Aug 07, 2008
  • anthonyshere Oct 03, 2010
    Someone has rung you and pressed the message button on their phone which means they lesft a mesage. Pick up the reciever and press the message button , this will call back that person clearing the message light on your phone. To change the settings or any other configuration on the phones you need to be on the phone which is plugged into the first port on the system, usually phone etx 101. then hit the program button on the display, hit (star) * the(hash) # keys and you will be prompted for a password. 1234 is the default. now you can program as you wish.
SOURCE:
How do I delete top hits and Bookmarks from iPhone5??
You will need to delete your browser cache to remove top hits.
To clear the browser cache:
From the Home screen, choose Settings > Safari. Tap Clear Cache.
To delete bookmarks:
Open any webpage in Safari and then tap the bookmark icon at the bottom of the browser. Once the Bookmarks window shows, tap on the edit button at the bottom right. The bookmarks will then show a red delete icon next to them. Tap the icon to delete the bookmark.
Hope that helps!
Oct 09, 2014 | Apple iPhone 5
How do I fit outdoor light
Electrician. That way you wont get shocked. You cannot see electricity
Aug 28, 2014 | Electrical Supplies
My device a red blinking light with a dark screen.
The red blinking light can mean a couple of things. First, It could mean that you have a message. If that is not the case, you caould have on the 'LED Coverage Indicator'. The LED Coverage Indicator tells you by having the top light flash eather Green or Red depending on coverage. If you are in a place that has good coverage it wil flash Green but if you have little or no coverage the LED will flash Red. To check if you have this setting enabled, first go to "OPTIONS" on the phone in the full menu. Once there, go to "SCREEN AND KEYBOARD". Click on 'SCREEN AND KEYBOARD" and scroll down will you see the option that says "LED COVERAGE INDICATOR". Click on that and switch it to OFF if it is not already there. Then click the back bottton and click SAVE. That should work. If it doesnt, I would call your phone carrier and ask them.
Feb 19, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
I have a panasonic phone system in the office a night switch was delegated to the phone. I have been away for 2 years and cannot remember how to use it. The red light on the top of the phone system is...
The red light means you have a message. Press the MESSAGE button and look at the display. A soft key will let you call or delete the extension that left the message. After they're all gone, the red light will go out.
Carl
Aug 20, 2010 | Panasonic KX-T7630 Corded Phone
My nokia 72 phone has suddenly switched off
Dear please reinstall its software. Problem will be quickly solved. Thanks
Jan 26, 2010 | Nokia N72 Cellular Phone
My LG Chocolate phone is in mute and I cannot get it out of it. Cannot hear any sound out of earpiece...can only use if it is in speaker phone mode...have I changed the setting somehow....is there a way to...
Not sure if this will help you, but when you slide the phone open, do you see 4 red lit-up indicators surrounding your center data wheel? On mine there are:
Red line - top left
Red line - top right
SPK - bottom left
CLR - bottom right
(Note that the indicators stay lit for about 20 seconds)
The indicator at the top left is the MUTE On/Off switch (you will see "MUTE" in the main display, just above the top left indicator). Although there is no real 'switch' there, you just push on that red indicator. It should vibrate when you turn MUTE on or off.
If the indicators go dark, the switch stops working. In that case, you have to slide the LOCK switch (this is a real switch, on the right side of the phone...it's the middle thing - above the MUSIC switch and below the micro SD opening). Just slide downwards and let go...the indicators should light back up, and you can use the MUTE switch then.
Hope this helps.
And BTW, the reason I am answering this question is because despite all I've just explained, my Chocolate MUTE swith, and all those indicator switches, have recently become intermittent. Which means when I am on an important call, after I switch to MUTE I find I can't get it out of MUTE. So if you try the above and it doesn't work, maybe your phone has a problem like mine....
Jul 07, 2008 | Cell Phones
Light comes on
First, it is normal for the line 1 light to quickly flash once every hour or so while it scans all of the phones. If the light is staying on though then this is a problem.
Look at all of the phones. All will show a RED light except for one that will have a GREEN light lit up for line 1. The green lighted on line 1 means that this is the phone that believes it has the right to use the line. When one phone uses the line all of the others are given a signal through a sub carrier of line one to light up in the color red.
I would suspect that the problem phone is a wall phone unit. This is because the switch on this phone is fighting the weight of the receiver versus gravity. There is not much tolerance in these switches as you will notice if you gently put your finger on the receiver at the top of a wall hanging phone.
If it is a wall phone unit causing this problem you can do 1 of 3 things.
1- you can switch this phone to a desktop so gravity is not working against you but for you.
2 - you can put an ugly looking spacer on the button so it pushes in farther.
3- you can try to perform inside surgery on the phone to adjust the tension of the spring on this button.
Jul 05, 2008 | GE 29488GE2 Corded Phone
Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
Feb 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Panasonic KX-T7630 Corded Phone Logo
1,283 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
