Question about AEG Dryers
AEG induction hob tripped mcb and when powered up again E6 error code displayed on induction hob. Only 1 of the 3 induction zones working, I believe other 2 share power. Model is 98030kf-sn prod nr 949593169
SOURCE: hob not working
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Posted on Nov 06, 2008
kel1guy2002
  • 3740 Answers
SOURCE: split ac runs for 2 hrs and MCB TRIPS
Hi and welcome to FixYa. I am Kelly
This is a sign of a compressor that has an armature dragging internally or the winding has a short to the chassis inside the compressor. Placing your hand on one with an internal short to the case will definately get your attention. USE a meter! (lesson learned the hard way too many times)
It really is not wise to keep trying to use the unit in this condition.
1. Higher electric bill
2. When compressor finally burns up and contaminates coolant system.... purging and cleaning the coolant system can be as costly as the compressor replacement.
3. There is a remote chance there is a chaffing wire from the outside unit to the inside unit. (Very remote)
A Service Tech will do a running check where he verifies the running amperage of the unit. High amperage = a bad / dragging compressor.
Kelly
Posted on Mar 02, 2010
SOURCE: AEG Oven model D98000VF - error code F8
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
Posted on May 07, 2010
  • 3 Answers
SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Error code e9 on hob aeg hk85440075
From another Post from Daniel T:
E9 on this hob means a user interface control board fault. This is the touch control board which you press to turn on.
What the service manual says is disconnect the hob from the mains connection and leave for 60 seconds. Then wire it back up and turn back on and see what happens.
If still the same then the user control board needs to be replaced.
To access this you need to remove the hob from the work top and remove the screws holding the glass on all 4 sides of the hob.
Then you can lift the glass top off.
From there you will see the user board in the front its the smaller board.
Replace this and that should cure the fault here.
If you need anymore info just get back to me.
My Zanussi induction hob flashes an error code E9 when try
Oct 30, 2015 | AEG Washing Machines
Induction fault e6
E6 - Defect Induction module or over temperature of coil sensor with Falcon User interface with production date before 2010
- Disconnect the appliance from the mains for 30 sec. If alarm still occurs after 1 min operation exchange induction module.
Over temperature of coil sensor with Falcon User interface with production date before 2010
- temperature sensor defect or wrong mounted.
  1. Check connector at induction module.
  2. Check the coil sensor, it should be placed even in the silicon carrier.
  3. Appliances with 3 zones, is the "Dummy" temperature sensor at the 2nd terminal mounted?
  4. Exchange coil with sensor.
  5. If above is without success, exchange induction module.
Dado
Jun 03, 2014 | AEG Ovens
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Aeg glass induction hob error code ER 21
reset the microwave. Disconnect the power cord, by 1minutes, and try again,the microcontroller is confuse.
If the problem persist you can be problem with the main controller board, repllace, but read your owner manual section troubleshooting for identi the error. download from www.retrevo.com
God bless you
Oct 27, 2013 | Microwave Ovens
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
We got an E3 error message on induction cooktop(induction hob), AEG 88101 K-MN, which followed a popping sound. What could it be? We checked the braker and fusers.
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Whirlpool induction ceramic cooktop error E6
Dec 15, 2009 | Cooktops
Dryers Logo
97 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
