Cant find disk drive during installation - Computers & Internet
    Problem Solver:
  • 15 Answers
Bad disk. replace it.
Posted on Apr 06, 2011
Cant get past boot screen. cant get to advanced boot screen or safe mode. cant run restore disk. power was lost during boot. boot corrupted.
try f-12 while it boots and select your dvd drive or cd drive, wichever contains you windows disk and boot from it if it still freezing up try it with the harddrive removed, to see if hard drive is bad
Jun 24, 2011 | Computers & Internet
I have compaq nx6310, i had issues with the os.once you touch a button it starts open other buttons and pages automatically. i tried restoring the system to earlier dates and the issue reduced. later on it...
Hi das4real! These are the things to consider.
  • Operating system disk - Try to test your Installation CD to other computer. If it doesn't work then you need to replace the disk
  • Optical Drive (CD/DVD Drive) - If Installation disk works then try to clean your Optical drive lens as it may be having a hard time reading the disk. Your Optical drive is working since you're able to format and able to start the installation. Cleaning the drive lens may do the trick.
  • Hard Drive - If Installation CD and Optical drive is clean. Then the last thing you need is to replace the Hard Drive. You Hard Drive might need replacement due to some bad sectors and the installation couldn't write anything on the drive that causes to freeze during installation.
I hope this helps you.
Mar 15, 2011 | Computers & Internet
Think Point!!!!!!!!!!!!!!!!! All these solutions sound nice. The problem is that even in "Safe Mode with Networking" I cant access anything on the computer that includes the start menu. So I cant install...
One way:
* remove the disk-drive from your computer
* install a different disk-drive (any old, 4GB or larger, disk-drive will work)
* install Windows onto that disk
* install anti-virus software onto that disk
* reconnect the previous disk-drive as a "slave" disk-drive
* launch the anti-virus software, targetting that "slave" disk-drive
* shutdown
* disconnect the different disk-drive
* boot from the original disk-drive, now that it is virus-free
Oct 19, 2010 | Computers & Internet
How to partition hard disk toshiba l500 P531 i have only c drive so i want partition may hard disk
you have to partition when you install windows. you cant just have a working operating system and add a partition. you would have to reinstall windows and add a partition during that process
Apr 12, 2010 | Computers & Internet
Hello I have a Problem for Dell PowerEdge 400sc and cant get windows xp installed, I am able to reformat the HD but cant get xp to load and at one point during the installation it says it cant install...
try another windows xp disk or burn another copy of the disk you have. it's also possible that there's a problem with the optical drive that you're using.
Mar 15, 2010 | Dell PowerEdge 400SC Server
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
Foxconn 761gxk8mbm/b cant find old or new sata h/drives on reinstall of xp
XP doesn't have the drivers for SATA - so it can't see them during the installation, and has nowhere to install to. You will need to make up a driver disk/CD/USB and use the "F6" installation option during the XP install to load new drivers.
Jun 30, 2009 | Foxconn Computers & Internet
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Why cant I Format the hard drive on a dell pc
when the system is u and running normally the comp is using the hardrive to run your computer to format it you must enter the installation of xp and format the disk during the installation process. there is a part of the installation where if theres a o/s on a harddisk it will allow you to format it just make sure you format it to NTFS if will be one of the selections
Mar 25, 2009 | Dell OptiPlex GX260 PC Desktop
Cant install program from DVD drive GWA-4164b
First check that your system meets the minimum requirements...ie. you have at least 512mb of ram, CPU of at least 2Ghz Pentium4 or equivalent(with off-board video), and your hard drive has >4GB of free space.....can view full list at:
http://www.amazon.com/Spore-Mac/dp/B000FKBCX4
Is SPORE on a duel layer dvd? If your drive is on the older side, you might try a newer one or you can try the following:
--take out an empty flash drive with
--go to a computer that will read the disk...if you have another computer or u can use someone elses
--put the disk in their computer and if the computer is able to read the disk, then put your flash drive in the computer and copy the disk onto your flash drive...
-y-ou can now try to install the program from your flash drive instead of using the disk...
NOTE: Trying this method wont cause any damage, but if the disk is encripted or if the install software is set to check for the disk during installation, then this may not work, but is worth trying since because a) even if it doesn't work, no harm is done, and b) you wont need to replace your disk drive if it does work.
Feb 12, 2009 | Acer (4432A-002) CD-RW Burner
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
