Question about Canon PowerShot G5 Digital Camera
Won't power up-- even with adapter
Having same problem you described in March-- what was your solution? New battery? New Adapter? New camera? Thanks.
I sent it back and paid upgrad to the G7... could not fix it...
Posted on Aug 06, 2008
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
No power to dell d620 laptop with or without battery, looking for a possible main fuse problem, where could i find it. thanks
The you most likely have one of two things for fuses places, (1) on the motherboard at the power connectors, or (2) there could be multiple fuses (ie. one in the battery, one in the power adapter, and maybe one on the motherboard.) the latter is rare but I've seen it. It doesn't really matter though because any fuses are most likely soldered in and you'll need special tools to change them without causing more harm then good.
However, if your computer is having a problem where it just plain won't turn on (ie. hit the power button and nothing happens at all), with laptops, you could need a new computer.
Sep 07, 2011 | Dell Latitude D600 Notebook
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
I was having trouble with the "low battery"
If you used a voltage 3 times the required voltage then you have probably damaged the camera beyond repair. There may be a protection fuse on the circuit board inside but locating and fixing this would require an experienced electronics technician. i wouldn't hold out too much hope of getting this camera repaired.
May 24, 2011 | Samsung Digimax A7 Digital Camera
What is a power adapter...my battery must be dead
A power adapter is the one that you plug into the AC mains to charge your battery. Please tell me whats the make and model of the camera and describe the problem in detail so that I can help you.
Sai.
Jan 01, 2011 | Cameras
New ideapad, doesn't have power
Based on your description of the issues you may be having a DC jack issue. I would suggest to insert the ac adapter and wiggle it around see if there any indicator of it try to charge the laptop. But in most cases that a laptop does not power on its due to the jack.
Feb 07, 2010 | Lenovo IdeaPad S10e Netbook
My dell inspiron600m does not even come on at
It sounds like the power adapter/charger has gone bad. If the adapter/charger is bad, then 2 things will happen.
1. The battery will not be charged.
2. the system will not be operable from the adapter.
If your adapter is not able to charge the battery or operate the device, then the battery is likely dead, which means youd have no power from the battery, and youd have no power from the adapter, and no power from the battery or adapter means it wont come on. I suggest taking that machine to a shop and having the adapter checked, as well as trying a new adapter.
Dec 13, 2009 | Dell Latitude D600 Notebook
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Canon Powershot G5 won't power on, even with adapter
If you can open it and you have experience and skills in fixing electronics, you can try in repair it.
Check the fuses on the printed board circuits.
They are labeled with a P, H or K in the middle of them.
Check them for zero ohms to test them with a meter,.
If you prefer not to do it, then it needs to be professionally serviced, which may be expensive (at least more than buy an used one).
Regards,
Regards,
Aug 06, 2008 | Canon PowerShot G5 Digital Camera
Canon PowerShot G5 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
