Question about Vacuums
Where can I get my Elna machine fixed? It is quite an old model and the zigzag function is broken. I am in the Toronto Downtown region.
  • 710 Answers
Here is the email address for Great Western Sewing Machine Services in Toronto: brian@gwsms.com
He was the service manager for Elna, Toronto for many years.
Also, Norm Sewing Machine provides on-site servicing. Here is there phone: 416-993-4466
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 06, 2011
What can you do for me?
Things break.
You do not mention the model number but belts are items that are stocked so no need to wait for one. I know of no stock faults.
Aug 06, 2017 | Vacuums
I need a replacement battery for my DirtTamer deluxe V2200
Get a SLA4-6 or UB645 model 6V 4.5Ah battery that says its size is: 2.76 x 1.86 x 4.17 inches.
Can't help you with your regional requirement but this is a good battery source:
http://www.apexbattery.com/rhino-sla4-6-battery.html
-Chris
Jul 25, 2012 | FilterStream Dirttamer Deluxe V2200...
Cant thread cotton correctly resulting in top cotton bunching around bobbin on my elna carina su sewing machine
Hi. Correct threading of your machine is absolutely essential for flawless function. I would suggest starting fresh, removing upper thread completely. For correct function, every threading point needs to be passed in the correct order. Every hole or thread guide should have thread going through it. Use a tweezer and pass the end of the cotton through each point, paying special attention to the tension discs and take-up lever. Double check to make sure you have light but firm tension on the thread (having lowered the presser foot, because tension is released when foot is up). Rotate the hand wheel slowly in it's normal direction to check function before attempting to sew.
Aug 20, 2011 | Vacuums
Manual for elna diva sewing machine
You can find a free download of the manual for the Elna 9000 which is almost exactly the same as the Diva.
http://pdfdatabase.com/search/manual-elna-9000-pdf.html
Let me know if you have any other questions. Thanks.
Mar 21, 2011 | Vacuums
My scrub brushes quit working on modelf5915-900 in less than one year this is my second machine in 3 years. Now I'm very angry with hoover company. Can this be fixed and how much will it cost me? Steam...
There are a couple of possibilities: the first and most simple fix would be to replace the brush-block, which simply releases from the bottom by pushing the retaining tabs free. If you pull this out and attempt to spin the brushes by spinning the green squarish "stick" coming out of the top of the block, you should be able to determine whether this is the cause. If the green stick is absent, or if the brushes are completely seized, a new block will run you anywhere from $50-$75 depending on which type it needs. If the brush block is functioning fine and isn't broken, you have probably seized the turbine which turns the brush block. To determine if this is the case, lay the machine on its side with the brush block removed, and turn it on (making sure you are clear of all moving parts, which in this case is only one..) and look at the white plastic circular piece with the square hole in it. If this is spinning, your turbine assembly is functioning properly. If not, it is most likely blown. If this is the case it is a fairly extensive and expensive repair, but if your machine is truly less than a year old either problem should be covered under warranty by an authorized hoover repair center.
-R
Sep 17, 2008 | Hoover Vacuums
Front switch broken on Kirby Classic III where I can buy it in Toronto, Canada area
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can contact a local dealer that can be found in the yellow pages under vacuum or you can call the Kirby factory to see if they have a local dealer or can send out the part to you from the factory. I will give some examples listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.AVACcorp.com 1-800-328-9430 they can ship out the part if you need it and if you cannot find it anywhere else.
Apr 18, 2008 | Vacuums
Vacuums Logo
130 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
