Question about Maytag Washing Machines
HOW TO USE THE WASHER? - Maytag Washing Machines
  • 17,970 Answers
Send us the model!
Posted on Apr 06, 2011
How do I change the windshield washer pump on 2002 kia optima
Windshield washer pumps are attached to the windshield washer fluid container. Remove that container and look for the washer pump. That is the only item with two wires connected to it. First remove hose connected to the washer pump and turn the washer switch on. IF water flows from the washer, your water lines are clogged, if no water flows, your washer pump maybe dead or there is no power going to the washer pump.
Try testing IF current is passing/present at the two wires by connecting as continuity tester or simply a small lamp. Switch the washer on and see if the bulb gets lit, if it does, there is power and your problem is the washer pump itself. Replace the pump.
Oct 04, 2014 | 2002 Kia Optima
Replace windshield reservoir
Windshield Washer Motor REMOVAL & INSTALLATION 1987-95 Vehicles
  1. Disconnect the negative battery cable.
  2. Drain or siphon the washer solvent from the reservoir.
  3. For 1987-91 vehicles, remove the brace.
  4. Unfasten the reservoir screws.
  5. Detach the electrical connectors and washer hose.
  6. If necessary, remove the reservoir from the vehicle.
  7. Remove the washer pump motor from the reservoir. Fig. 1: Location of the windshield washer fluid reservoir and pump - 1987-91 vehicles 89636g50.gif
    To install:
  8. Install the washer pump motor on the reservoir. Make sure the pump is fully seated in the reservoir gasket.
  9. Position the reservoir in the vehicle.
  10. Attach the electrical connectors and washer hose.
  11. Install the reservoir retaining screws.
  12. Install the brace.
  13. Fill the reservoir with washer solvent.
  14. Connect the negative battery cable, then check for proper washer pump operation.
1996-99 Vehicles
  3. Detach the electrical connectors from the washer.
  4. Disconnect the hose from the washer pump.
  5. Loosen the nut at the bottom of the washer reservoir.
  6. Unfasten the 2 nuts, then remove the washer solvent reservoir.
  7. Remove the washer pump from the container.
  8. If necessary, remove the solvent lever sensor switch from the washer solvent container. Fig. 2: Exploded view of the washer fluid reservoir, pump and level sensor 89636g51.gif
    To install:
  9. Install the solvent level sensor switch in the washer solvent container. The tab on the solvent level sender switch must be lined up with the slot in the hole.
  10. Install the washer pump into the reservoir, making sure the pump is pushed all the way into the container seal.
  11. Install the washer solvent reservoir and secure with the 3 nuts. Tighten the nuts to 44 inch lbs. (5 Nm).
  12. Attach the electrical connectors to the solvent level sensor and washer pump.
  13. Connect the hose to the washer pump.
  14. Fill the reservoir with washer solvent.
  15. Connect the negative battery cable, then check for proper washer pump operation.
Nov 09, 2010 | 1997 Pontiac Bonneville
Duet steam washer -- light for washer cleaning
Affresh
Washer Magic
Tide washer cleaner
Bleach
All in order of what is best for cleaning your washer
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mercury villager 1994 washer pump not working
the pump motor likely is bad. get a used washer fluid reservoir at a pick n pull yourself or at car-part.com. page with * is lowest cost.
Pump and Reservoir, Windshield Washer Removal
  1. Disconnect the battery ground cable (14301).
  2. Raise and support the vehicle.
  3. Remove the RH wheel (1007).
  4. Remove the RH front fender splash shield (16103). Refer to Section 01-02 for the removal procedure.
  5. Remove the windshield washer reservoir top bolt.
  6. Disconnect the windshield washer reservoir fluid level sensor electrical connector.
  7. Disconnect the rear window washer pump electrical connector from the rear window washer pump.
  8. Disconnect the windshield washer pump electrical connector from the windshield washer pump (17664).
  9. Place a suitable drain pan under the windshield washer reservoir (17618) and drain the washer fluid.
  10. NOTE: The rear window washer hose end is color-coded, matching the connector on the rear window washer pump. Match the colors to ensure proper installation.
    Disconnect the washer hoses from the windshield washer pump and the rear window washer pump on the windshield washer reservoir.
  11. Loosen the two windshield washer reservoir side bolts.
  12. Remove the windshield washer reservoir by sliding it out of the side slots.
  13. Remove the windshield washer pump.
    Installation
To install, reverse the removal procedure. Tighten the lug nuts (1012) to 98-118 Nm (72-87 lb-ft).
Sep 09, 2009 | 1994 Mercury Villager
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Windscreen washer.
WASHER MOTOR 1. With the washer motor installed to the washer tank, fill the washer tank with washer fluid. 2. Attach the positive (+) lead from the battery to terminal 2, and negative (-) lead to terminal 1. 3. Check that the washer motor runs and washer fluid is ejected.50a9b90.gif SERVICE ADJUSTMENT PROCEDURES 1. Check the washer fluid contact point. 2. Adjust the washer fluid contact point by using a metal wire to move the washer nozzle ball.4a5c2e0.gif48e95c0.gif 3. If the amount of washer fluid is too small, check for clogged, bent or crushed washer piping. Check the chipped points too, because the tube might be crushed.
Jun 25, 2008 | Hyundai Motor 1995 Accent
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
12 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
