Wanted to dim the scree but couldn't find the switch for it
  • Maël Cournoyer-Michel
    Maël Cournoyer-Michel Apr 06, 2011
    Please give us your laptop model and we will look in it,
    Thanks!
    President:
  • 1,623 Answers
If you press the fn key and keep it pressed then press one of the function keys they will have a circle with lines projecting out of it, they look like a pic of the sun, there should be two one for increasing it and another for decreasing the brightness
Posted on Apr 06, 2011
Replace dimmer switch for 2007 Buick Lacrosse
Are you sure you want to do that ? Are you guessing that's the problem ? Do you know what DTC'S - diagnostic trouble code's are ?
DTC B2610
The body control module (BCM) applies a voltage reference through the instrument panel (I/P) dimming voltage reference circuit to the interior lamp switch. When the switch is placed to the desired position, the dimmed voltage setting is applied from the interior lamp switch through the I/P dimming return circuit to the BCM. The BCM applies the dimmed voltage to the I/P lamps supply voltage circuit.
Do you know how to do electrical testing ?
Reconnect the lamp switch assembly.
Disconnect the body control module (BCM) connector C1.
Using a DMM, measure the resistance between the I/P dimming voltage reference circuit and the I/P dimming control circuit.
Vary the I/P dimming switch from full bright to full dim.
Does the DMM, display change?
Did you perform the Diagnostic System Check - Vehicle?
Yes - Go to Step 2
No - Go to Diagnostic System Check - Vehicle
Verify that the interior backlighting does not dim.
Does the interior backlighting operate normally?
Yes - Go to Testing for Intermittent Conditions and Poor Connections
No - Go to Step 3
Do the instrument panel (I/P) lamps dim?
YES - Go to Step 13
No - Go to Step 4
Do the class 2 lamps dim?
Yes - Go to Step 5
No - Go to Step 6
5
Test for a short to battery positive voltage in the I/P lamps supply voltage circuit. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Yes - Go to Step 14
NO - Go to Step 13
6
Disconnect the lamp switch assembly.
Does all the illumination of the backlight components turn OFF?
Yes - Go to Step 8
No - Go to Step 7
Nov 18, 2016 | Buick LaCrosse Cars & Trucks
Screen not bright
Screen back light is out..there only $5 or $10 on ebay..Wasy to change..watch toutube vids..
Dec 07, 2013 | Dynex 7" Dx-dpf7-10 Digital Photo Picture...
Dose samsung corby gt-s3653 supports whatapps
Switch your cellphone to iPhone and fix your problem!
Apr 05, 2013 | Samsung GT-S3653 2 Megapixel Camera-Touch...
The backlight in my ipod nano (5th gen) wont work. i can still see whats on the scree, but its really dim. I haven't dropped it, or put it in any water, but I bought it over a year ago so its out of...
You will need to get a new LCD Panel for it. If you feel comfortable fixing it yourself you should be able to by the parts from ifixit.com
Amardeep
For more tips, visit my blog at http://thegeektweet.wordpress.com
May 27, 2011 | Audio Players & Recorders
Got a very dim light scree on my travelmate.can't increase it with fn.
Hi
If you look at some of the other keys on the keyboard there should be 2 keys with lights on them mine are on the right hand side what you need to do i believe is press the Fn key as well as the up light key at the same time and hopefully that should make your screen brighter
Nov 15, 2010 | Acer TravelMate 2300 Notebook
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
I AM INSTALLING A TACHOMETER IN MY 89 MUSTANG GT AND I DONT KNOW WHICH WIRE TO USE ON THE DIMMER SWITCH FOR THE TACH LIGHT?
Grab a $5 12volt test light & probe back of switch where wiring comes into switch, for wire that has power when you pull lights on. If that's when you want it illuminated. If you want it too go bright or dim with dash , poke wires until you find that one, while turning switch to bright dim, and test light will do same.
Jul 05, 2009 | 1989 Ford Mustang
Dim Dashboard read
On most vehicles you have a dimmer switch ( not talking about headlights) which you can adjust how bright or how dim the dashboard lights are because some people want them bright and others prefer dim either check your owners manual or check all around for it from drivers seat ( within drivers reach) when you find it if you can't adjust it then you want to consider replacing dash lights or switch.
Apr 01, 2009 | 2001 Audi A6
I need to replace worn put power switch on panasonic plasma scree
Hi, you can check https://www.discount-merchant.com. They have a lot of plasma and LCD parts. You can even give them a call for free tech support.
Mar 23, 2009 | Panasonic Televison & Video
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
