Question about Bosch Exxcel WFX 145S Front Load Washer
Bosch EXXCEL 1400s. Clothes have a horrible damp smell when they come out of the washing machine. have clean and washed out all pipes but sill a damp smell inside machine. What is wrong with it? So bad have had to borrow a hotpoint and that is fine so it is not the exterior pipework.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Yes,,,,,1 coup of soda crytal
1 coup of any vinegar
1 coup of diswasher salt
put it on 90 degree empty wash..........and see the result.....
my name is khan.
Posted on Dec 10, 2016
  • 111 Answers
SOURCE: My Bosch Exxcel 1400S Express
Bummers. Sounds like the clutch is out. (If you can hear the motor spinning but not the drum, I'd say that's it. Especially if the machine has a number of years on it.)
I once looked into having a service man come fix a clutch. He said it would be cheaper to buy and new washing machine and have the old one hauled away.
Good luck.
Posted on Nov 13, 2008
  • 3463 Answers
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Posted on Jan 02, 2009
SOURCE: Bosch Exxcel 1200 Express Washing
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Posted on Jan 24, 2009
  • 3463 Answers
SOURCE: Oily substance collecting in the door's rubber seal.
It is not oil, but a build up of grease and living bacteria, caused by doing too many low temp washes.
The only permanent solution is to replace the door seal, and at least once a month, do a hot boil wash without clothes in, but with powder or detergent in as normal.
This is called a maintenance wash, and is now recommended by all manufactuers.
Please rate my solution.
Posted on May 13, 2009
SOURCE: instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
Posted on May 23, 2009
Bosch Axxis washing machine: clothes small moldy after washing!
Due to mainly running low temp washes and bacteria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe) many machines will begin to smell, generally the smell is described as a damp flannel!. This can be transferred to the wash load if like myself you tend to put a load on before going to work and then removing when you get home. (The washing is clean but smells disgusting!!!)
Run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) If you buy stores own as it is cheaper than miltons. The first time you need to do this, run the cycle twice to be sure it was cleared out.
My machine is six years old and the first smelly signs were when it was about a year old, I do mainly 30 and 40 degree washes with and occasional 60.
I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months.
Hope this helps. Roni.
(ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Sep 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
I have a bosch exxcel 1400s washing machine and after about five minutes it trips the house electrics, can you help?
try disconnecting the Heater element, Both wires the plug back in and try..Good luck
Oct 09, 2009 | Washing Machines
Ive just brought a re-conditioned bosch classixx washing machine,
boil wash the machine with old towels and powder, 90 degree wash will bring out the bleach in the powder and the old towels will throw the bleach around the tub removing the bacteria that has grown in the tub, the bacteria comes from the washing powder to eat the dirt in clothes and sometimes gets left in the tub and pipes (most people only wash at 40 degrees the bleach wont come out the powder until at least 60 degrees hence the build up and smell). you may have to do this twice to get it smelling good, remove the drawer also and clean off any bacteria with a cloth and spray bleach.
Jul 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing comes out smelling horrible! Any ideas?
It is not the washer that is causing the prob, more likely to be coming from waste pipe, and or sink if the pipe is connected to the sink waste pipe.
Check and clean filter in washer if it has one, and remove waste pipe from washer and check outlet is not partially clogged up with sediment and other substances.
If pipe goes into sink waste, then pour a sink pipe cleaning fluid of some description down sink waste.
Also make sure you are not doing too many low temp wshes, as this can cause a prob as well
Do a boil wash at least once a month without clothes in but with powder in.
This is called a maintenance wash, and helps keep the inside of washer clean, and free from smells.
May 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My Bosch Exxcel 1400S Express (WFX148SGB) just doesn't spin anymore. Everything else seems to work fine?
Good luck.
Nov 12, 2008 | Bosch Washing Machines
Washing machine does not always take the conditioner
take out the soap draw and try giving it all a good scrub mith a tooth brush if that doesent work it could be problem with tap in the back bosch machines are always worth repairing though exellent peice of kit
Nov 11, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machine Smell
.I would try running some washer magic through it first. also when you finish a load a clothes leave the door open for a while to air unit out.Your unit is probally smelling moldy after each wash, leave door open to air out the tub You can get washer magic at your local appliance parts store.
Dec 01, 2007 | Washing Machines
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Bosch Exxcel WFX 145S Front Load Washer Logo
75 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
