Question about RCA 20F524T 20" TV
My antenna cable input broke on my rca 20F524T. Can I get replacement part and also remote control?
  • RCA Master
  • 8,457 Answers
This tv problem a must to be repair by a tv Tech.Get an estamate for a good price compare for a new LCD tv price which is better for u,make ur choice.Because the antena cable input hole it broken not easily repair require new or used part and have be modtified and and re atached it back in and have a major resoldering work to do.Try website Remote.com to buy an original remote,if u plan to fixed this old tv.
Posted on Apr 06, 2011
I have 37LC50CB LG tv. When I turn on with new DTA remote control come up channel # 56-1 and cloud(nothing) on screen Then I...
Your DTA remote cannot turn on your LG TV. Find the red/white/yellow cable that was in the box with your DTA and connect it between the appropriate RCA outputs on the rear of the DTA and the corresponding RCA inputs on the rear panel of your TV. Disconnect the cable connected between your DTA and the antenna input of your TV. Be sure your DTA is on. Turn on your TV and select your DTA as the input source. You may have to press SET UP on your DTA remote to display the set up screen on your TV. Do a channel search and you should be all set.
Nov 24, 2016 | LG Televison & Video
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Dec 28, 2009 | RCA Televison & Video
Have inherited RCA television with AV input on back, but remote and using buttons on TV allow only channels 4 and 7 to be be seen. How do you make televsion recognize AV input from back? RCA model F20600...
Bring up your video menu, make sure the cable/antenna mode is set correctly. Also do channel search/ auto program. If your AV is operating a DVD player etc., there should be a button to switch from TV to AV. If you are trying to input Cable/Antenna to AV jack you may have it plugged into wrong jack, it should go into 'antenna/cable in' jack. Hope this helps.
Nov 08, 2009 | Televison & Video
Which hole do I plug the cable into antenna digital input or ante
Hello ruthharris,
I think the antenna is built in :S dunno exactly may be .. btw there is [Antenna] button on the remote control
You can download the Manual of this TV by Clicking Here
Thank you for using FixYa.
Apr 12, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Video on tv
go to"remote controls .com " You should be able to locate your original there.
Feb 18, 2008 | Emerson EWF2004 20" TV
42HDS69 cable input is only thing working
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If youdon't have the original remote and can't find it ever then the only way to reachyour tv is through coaxial antenna port. Soyou can buy an rf modulator ( very cheap) and connect your red yellowand white cables (rca cables from a dvd, game consoleetc) to the modulator then connect the modulator to your antenna with acoax cable. This worked for me. It placed the connection to channel 4and other channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Nov 24, 2007 | Hitachi 42HDS69 42 in. Plasma Television
RCA RCR450 remote
here is a website that can help you https://www.rca.com/secure/service/contactrca/1,,,00.html
Apr 01, 2007 | RCA RCR450 Remote Control
RCA 20F524T 20" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
