Question about Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2 SATA II Solid State Drive (SSD)
Samsung hd154ui hard drive - cannot format above 1 TB says 500gb available but does allow one to create a partition
  • Samsung Master
  • 27,725 Answers
The drive has developed some bad sectors on it
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
or you could download partition magic
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 Partition Magic 8.0
note: after you loaded your operating system you will have to change the boot order back to your hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
Hope this helps you
Posted on Apr 06, 2011
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Not able to detect the disk
We're going to need more information to troubleshoot, but if it's a new drive that's never been set up follow the instructions below. If these instructions aren't helpful, then please post back with more info and I'll help you further.
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click "Administrative Tools."
4. Double-click "Computer Management."
5. Select "Disk Management" under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hard drive.
Good luck and thanks for using FixYa.
Apr 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Tried to partition drive using disk mgr in windows xp sp2, won't allow a right click to partition into 2 (1) one tb partitions
Delete any existing partition on the drive.
Be careful! This will delete any "data" files on the disk-drive!
Then, you should be able to create an "extended" partition, with two "logical" drives inside that "extended" partition.
Oct 21, 2010 | Fantom Drives FD GForce MegaDisk 2TB ...
Samsung HDD not seen by Vista I recently purchased a Samsung HD154UI Hard Drive for my Vista 64BIT System. I have enabled the hard drive in the Bios. I now have a 500GB drive on SATA 1 and the new...
This won't be the best solution for you perhaps because I'm not a windows guy, but download the gparted (just google for gparted) cd image, burn it to disk and boot it up. Use that to partition and format the drive.
Aug 05, 2010 | Microsoft Windows Vista Home Premium...
Hello, I bought WD My Book Essential 1 TB but whenever i connect it to my Samsung DVD player it doesn't get recognized. Any help? Thanks
Most probably the format of your hard drive is NTFS. Samsung DVD players only recognize FAT32 formats. If you have the patience and resources try to change the format of your hard drive to FAT32. Better yet since it is a 1TB try to create a partition one NTFS and one FAT32 because FAT32 cannot go beyond 4GB for files.
Hope this helps.
Jul 30, 2010 | Western Digital Passport WDXML800UE...
Samsung Ecogreen F2 (HD154UI) 1.5TB HDD not found on 2/3 PCs?
Vista and XP are a pain in the **** to make work as a network. as for the driver. Vista may have drivers built in to see it. and XP may not. see if there are any drivers for the external drive on the samsung website.
May 09, 2010 | Computers & Internet
Humax pvr can not read my maxtor 500gb harddrive why is that?
NTFS
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Mar 08, 2010 | Maxtor Hard Drive
Hi, I just bought iomega 1 tb select desktop hard drive, i have a laptop and i have connected to an USB but it is not showing up.
You may need to format the hard drive before you use it.
If your using a PC....go to Control Panel>Admin tools>Computer managemant.Disk Management....Create a new partition and format the drive (NTFS).
Using a Mac go to spotlight and type Disk utillities, partition the drive...
Oct 29, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2 SATA II Solid State Drive (SSD) Logo
379 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
