Modem problem in workgroup
i am facing problem with modem. i have 20 pcs in workgroup.
i can use internet on only one computer which i have connected. other pc cant access internet.
could tell me the solution.
  • 80 Answers
Enable your internet sharing protocol so that the other workstation can connect to the internet...
Try configuring the ip address as well as the gateway of your worksation...
Posted on Aug 06, 2008
Network a Konica Minolta printer
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
Jul 27, 2012 | Konica Minolta Office Equipment & Supplies
Hi i am chinni working in a bpo company. i wanna configure dhcp network in my office. can any body helps me
Hi, by default the Linksys router is set to DHCP... So all you have to do is connect an ethernet cable from your modem to the WAN/Internet port of the router and then connect a PC to one of the ports, see if that will be able to connect to the Internet if not, try to do a power cycle (turned off everything and then turn on the modem first and wait for all the lights to be stable and turn on the router and then the PC) once the computer gets online you may connect the rest... should you require to connect more than 4 PCs, you may need to have a switch but with this setup the physical connection should be
Modem to WAN port of the Router to Switch port and all PC should be connected to the Switch's ports
Mar 27, 2010 | Linksys EtherFast 10/100 16-Port Workgroup...
File Sharing
Here’s a very short summary of how to create a home network:
1) Create a named Workgroup (computer network name).
In Windows, the defaults are MSHOME or WORKGROUP, but you can choose your own
2) Add computers to the named Workgroup
3) Enable file and/or printer sharing.
Here are some resources to help you:
1. Windows XP has a wizard to walk you through it - see tutorial here
2. For Vista, try this link for a detailed overview: http://technet.microsoft.com/en-us/library/bb727037.aspx
These links might help too:
http://www.dummies.com/how-to/content/how-to-create-a-pc-network-workgroup.html
http://www.dummies.com/how-to/content/connect-to-and-share-files-with-other-pcs-on-your-.html
3. When it comes to sharing folders, there are two main ways to do this. You can either 1) right click the folder and enable sharing through the shortcut menu., or 2) add the file/folder to ‘Shared Documents’ (for XP) or ‘Public Folder’ (for Vista).
Hope this helps, but please come back to Fixya if you have any difficulties. Good luck!
Jan 25, 2009 | Belkin (F5D8231-4) Wireless Router...
Using multiple networks
if you are using windows 2000 or later start the routing and remote access service (make sure to set it to automatic) and that should solve your problem.
Jan 13, 2009 | Intel REALTEK nc-r150201 Network Adapter
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
I do have i mdb file on 1 pc and i need to shared wit 3 pc
First make sure all 3 PCs are on the same workgroup or domain. You can verify that in the System Properties, accessible by right-clicking the My Computer icon and selecting Properties, then selecting the Computer Name tab; below the Full Computer Name will be the domain or workgroup.
Once all 3 PCs are on the correct workgroup/domain, navigate to the folder where the file in question resides, and right-click the folder itself (not the file) and select Properties, and then the Sharing tab. From this tab you can select to share the folder, and set access restrictions if needed, and then the other 2 PCs should see the new share in their Network Places within a few minutes.
Dec 21, 2008 | Microsoft Office 2003 Basic Edition...
Wired router connection
To my knowledge, yes. "dial-up internet" connotes standard modem attached to a computer unlike DSL modems (non USB) that are stand alone. Therefore the dial-up internet modem should be connected to a single computer. That PC then would have to enable its Internet Sharing for others in the network to access the Internet. This is accomplished by hooking all the PCs to a single network using a hub/switch. The router can perform this function (hub), however, all the PCs in the network would have to use for their Default Gateway IP address not that of the router but that of the PC with the dial-up internet modem. Having said that, it would then be necessary to use static IP adds in all the PCs. The built-in firewall and DHCP features of the router would not be necessary.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 23, 2008 | Microsoft Broadband Networking MN-100...
Hey BIgz19
It is not illegal, of course!
I assume you do have an ADSL or Cable modem connected with LAN cable.
You connect your modem to the wall outlet/splitter with a telephone cable.
Then then modem is connected with LAN cable to your router's WAN port and then two PCs to any of 4 LAN Ports.
Please follow these steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect one PC to one of the 4 LAN ports of your Router with a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres: 192.168.2.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
Open your browser and type http://192.168.2.1
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
PPPoE.
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APPLY, and again APPLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable.
Now:
if you've typed your User Name and Password correctly in PPPoE fields,
and
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the other PC and do the same above.
Connect the NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
You should check if both PCs are in the same WORKGROUP !
Right-click on My Computer, click Properties, then click 'Computer name' tab, and down on CHANGE. In the Workgroup field type the same as the Workgroup name of the other PC, then APPLY and OK.
This action need a REBOOT. Do reboot!
That's it!
Hope it helped.
Mar 16, 2008 | Edimax BR-6104K Router (br6104k)
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
