Question about Power Acoustik XL2-820 Car Audio Amplifier
Could you please send circuit board PMC-073-71 amplifier XL2-820, accidentally spilled acid please
My battery is leaked my camera is not working want to eject casset out of it tried connecting charger but didnt helped
A leaky battery is not good news. First, the "stuff" that leaks from a battery is acid. It will burn clothing and your eyes if it comes in contact with them. Wash you hands completely before touching your clothes or rubbing your eyes after touching the battery acid!
Next, the acid is conductive. This means wherever it has spilled, it is like a copper wire. If the spill is across the charging terminals, it acts like a dead short circuit. This conductive path radically changes the circuit(s) and will have to be eliminated before going further.
To have hope of this device working again, the acid will need to be thoroughly cleaned / removed The acid is usually a heavy fluid or gel (depending on the battery type) and can be cleaned with solution of baking soda and water applied & scrubbed with q-tip. Baking soda neutralizes the acid and the water help dissolve the dried-on acid. You'll need to exercise care to not let the solution get on / in electronic components. If the acid has entered some of the electronics - and isn't merely topical - you may have success restoring functionality to the device.
Wipe away excess solution and allow to dry. Power up and try again. Good luck!
Oct 08, 2013 | Video Cameras
What would nail polish remover spilled on key board do
most often nothing once it has had the time to fully dry out.
Apr 24, 2012 | Toshiba Satellite C655-S5212 Laptop
Magellan gps 315 battery leaked and will not power up. what could be wrong
The acid from the leaking battery most likely shorted out the circuit board. You can trying cleaning of the acid spill with a little alcohol on a Q tip. The batteries are probably also no good and you will need to replace them also. If this does not work you can try taking the unit apart and cleaning any further acid that has leaked to the inside. Thanks for using FixYa
Here is a link to the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000013645.pdf
Jun 19, 2011 | GPS
Hi. I accidentally spilled coffee on my Asus EEE PC 1000H Laptop. Is it true that its keyboard is waterproof? If so/not, what should I do to avoid damaging it permanently? I've been using it for 2 hours...
When this happens, you should fully disassemble the netbook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the netbook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Feb 01, 2011 | ASUS Eee PC 1000HA Notebook
Plz send me ssb-120 pa amplifier circuit digram
Hi i think this is what you are looking for, takes a while to load but checked and its the full instruction manual.
http://ahujaradios.com/Literature/SSB-120_OM.pdf
please rate :)
Feb 05, 2010 | Alpine Audio Players & Recorders
Ink spilled inside
It may be too late. That ink is caustic to the circuit board. To get to it is a real chore and probably not worth the effort.
Jan 24, 2010 | HP PSC 950 All-In-One InkJet Printer
Schematic (or just R10) for Rampage AMP522A Car Audio Amplifier
2 years later... I just picked one of these up at a yard sale... R10 is actually a diode. The code is buried, but ends in N1.
Hope this helps!
Sep 14, 2008 | Audiovox AMP522A Car Audio Amplifier
Greatful if you can help me
i have a pmc with bad logic board. I want a logic board to fix mine. But I can sell u my screen.
Dec 09, 2007 | iRiver PMC-120 Digital Media Player
Projection TV Convergence
they have inherent problems with the glycol oil used to cool the tube leaking past the bladders & onto the boards.... & it's conductive :p
Sep 30, 2007 | Televison & Video
Power Acoustik XL2-820 Car Audio Amplifier Logo
35 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
