TV just over 1 year old. Red light comes on sometimes but no picture? Got number of repair man he said sounds like a power supply problem
  • 822 Answers
Could get used power supply board off ebay...........
or if you can use a soldering iron.....replace the caps on your ps board.........
cheers
Posted on Apr 06, 2011
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
May 01, 2008 | Televison & Video
While watching tv on saturday, my screen went black and their is absolutely no picture nor sound can you tell me if i can fix it as it is only 3 years old
Any indication of power? red light? blinking light? Sounds like the power supply failed if no indicators on. 3 yrs is an average lifespan for these new sets.... unless you are a tech, it's time for a repair shop. Get an estimate first, sometimes its not worth getting an old set fixed...
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
LCD Tv will not turn on
Power supply issue. Still under warranty?
Aug 24, 2017 | Zenith ZLD20A1 20.1 in. LCD Television
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture or sound. Red light comes on then goes off.
I had the same problem with my LTP227W and it is also about 4 years old. Took it in to be fixed and they found it was two capacitors in the power supply. Parts for this TV are not available anymore but they were able to repair the power supply. The TV works fine now. Hopefully I can get another four years out of this. Repair cost was $150.
Oct 24, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
