Question about Dishwashers
Miele g1040i wash drying and end lights flashing. Appliance will start pumps out for 3 seconds and then the lights flash.Appliance will continue to pump out for 2 minutes approx.I have checked pump and overflow micro switch both of them are working normally and outlet is clear.
gwshaw71
  • 83 Answers
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
IFIXALL
  • 868 Answers
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
vickygomar
  • 460 Answers
SOURCE: Miele G570 dishwashher tripping ELCB at end of
this information will help U  please copy n paste
http://www.youtube.com/watch?v=nr6tIO5iNSc
If you need more assistance please contact us.
Was this helpful?
Posted on May 13, 2009
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
Kenmore Elite 665.15929001 Dishwasher, flashing Sani-Rinse light, won't start
Kenmore is **** with a double PP go buy a Maytag or GE and throw it threw the appliance dept like the Discount tire guy did on TV. I have asked the same question on 4 different blog's and no answer. The question to where they were actually built is unavailable. They only warranty products for 1 year and their disclaimer's add up to when you walk out the door. They are just JUNK! sorry I do not know the answer, first you will pay the repair man then end up buying a new one anyway. Same as me..Peace!
Nov 14, 2012 | Dishwashers
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
