Question about Casio Watches
Need manual for watch #3319 - Casio Watches
How to set my 3319 case watch
Google (Case)(3319)(manual) without parens for instructions.
Nov 13, 2016 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Casio wrist watch - need to tune of the hourly chime?
Hi,you need to look at the user manual..
just in case ,if you need to download a soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Mar 04, 2011 | Casio AMW320R-7E Marine Ana-Digi 100m...
Need a owner's manual for this watch ! Please help
Hi albeerd,
You can download all ARMITRON watch manuals/instructions from this link.
http://www.armitron.com/watch_instructions.asp
Hope it helps.
Thank you for using Fixya.
Dec 24, 2010 | Armitron 40/8125BLK Digital Sport Watch
Need a CASIO WVA470 Watch Manual
casio has most of their watch manuals online , you can find them here, You will need the code on the back of your watch and just enter it in
Oct 18, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
I have a japense cybeat watch manual,i need it in
i have a cybeat 5 bar watch, i need a manual how to set the time and date would you please send manual to my email add jhoy_pagtalunan@yahoo.com thank you
Mar 01, 2010 | Watches
How do i shorten the band on my casio 3319
You look for the end of the link that has a screw like notch and tap it out with a small screw driver (like a eyeglass screwdriver or any thing you can sub,) and pull out with a needle nose pliers. Be careful and out the band on a rubber or paper surface though.
Providing you have the tools. I did mine in 3 min.
Oct 17, 2009 | Casio Watches
The strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Aug 14, 2009 | Casio Watches
Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
Feb 24, 2009 | Fossil CH2331 Wrist Watch
Watches Logo
166 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
