Question about VuPoint PDSST410VP
How do I delete the pictures from my scanner once I have down loaded them to my computer? The few instructions that I got with it don't seem to explain how to remove them.
I need to scan something from printer to computer an don't know how to do it. Can you help me please?
Hi:
It's real easy, all you need to do is load the software that comes with your printer in your computer, once it's loaded. Put the picture facing down and go to your start button (left hand bottom side) click on it, go to programs, go to lexmark and click on Lexmark All-in-one Center. Once the window is open go to your right upper side and click on Preview Now. Your printer/scanner should be scanning the picture and this one will appear on the blank space, once it finished you can crop the picture as you desire and then click on the Scan Now button. That's it!
More easy: On the left hand side of your printer there are three buttons; power, copy and scan. Press Scan and the all in one Lexmark program will open and you will see the picture in your computer, crop it and press Scan.
Sep 15, 2011 | Lexmark X2350 All-In-One InkJet Printer
I just bought the DANE-ELEC Micro SD. It comes with the Micro Card and the USB and the SD Adapter. I am trying to get the pictures from my phone to my computer. There are no instructions so I do not...
Put the Micro SD card into your phone and transfer the pictures to it. Once you have transferred the pictures, take the card out of your phone and put it into the SD Adapter and then into the USB Adapter. Once you have done that plug the USB Adapter into your computer and wait for it to load. After waiting a few seconds, click start, my computer, then double click on the SD card icon. Your pictures should load and you should be able to transfer them to your computer.
Jul 29, 2011 | Computers & Internet
I opened my X018 Camera package and there wasn't any software or instruction book included. Please help. drypete@aol.com
-Using the USB cable that came with the camera, connect the wider end of the cable to your computer and the smaller end to your camera, on the left side.
-Power on the camera. After a few seconds a new window will appear on the computer screen. The new window allows you to use the Scanner & Camera wizard to move your pictures to the computer. Select the wizard and follow it's steps to approve the new location for your pictures and then proceed.
If you don't have the USB cable, remove the memory card from the bottom of the camera and find the part of your computer labeled Media Cards. Insert your memory card into the slot labeled SD. After a few seconds a new window will appear on the computer screen. The new window allows you to use the Scanner & Camera wizard to move your pictures to the computer. Select the wizard and follow it's steps to approve the new location for your pictures and then proceed.
May 09, 2011 | Vivitar Cameras
My child broke the disk that came with camera. I tried to go online at aries and get a download. this didn't work now i'm stuck with a aries picture on the my computer screen that i can't delete. can you...
Under the circumstances, best solution is to do the system restoring.
Go to My Computer Click System properties. Select System restore and follow instructions therein. NOTE you select the system restore date/point before you downloaded Aries program. Once the action is completed you will find that your computer has been restored to a point before you downloaded Aries. The down loaded program will not be there.
Apr 04, 2011 | Cameras
I am trying to scan a picture onto my computer
1. Turn on your computer, wait for it to boot up, then turn on your printer.
2. Double click on the " HP Photo Imaging Director " icon on your desktop, it was placed there
when the printer was installed on your computer. A screen will appear which will show the
scanning options of your printer. Do not make a selection at this time.
3. Place your picture on the glass top scanning surface and lower the lid.
4. Click on " Scan Picture " from the director screen.The scanner will make one pass and allow
you to look at the result, it will then make another pass, completing your scanning operation.
5. Your picture can be viewed on HP Photo Gallery and " My Pictures " folder.
Have a Nice Day.
Jan 21, 2011 | HP Officejet 4315v All-In-One InkJet...
Transfer pictures from memory card
Ok what you need to do is you need to put your memory card into your computer/mac and down load the files once that is done delete the photos on your camera!
Mar 27, 2010 | PANDIGITAL 6.0-Inch Digital Picture Frame...
Disk says not enough space on disk to finilize?
Each time you execute finalization, the disc remaining space will decrease by approximately 13 MB. If you don’t have enough room, it won’t allow you to finalize the disc.
To finalize this disc, you have to delete some pictures to make enough space. But don’t worry, before you delete those pictures, you can save them to your computer.
Find out the CDs came with your camera, refer your manual page 51 - 61 to install ‘PIXELA PTP Manager’ , connect your camera and computer with USB cable, and copy some pictures to your computer, then delete the pictures on camera side. If still not enough room, copy more and delete more. make it enough to do the finalization.
Apr 07, 2009 | Sony Mavica MVC-CD250 Digital Camera
Hp photosmart 2610xi does not scan.
Remove all hp software and drivers from control panel>add remove programs. Then go to control panel>system and go to hardware and then device manager, then delete your printer/scanner from the list by right clicking and 'uninstall'. Then restart, and make sure you printer/scanner is unplugged and off. Then once your computer restarts go to hp's website and make sure you selected the right country (at the top), then go to support & drivers and download the software/drivers that are for your printer/scanner. Once drivers/software is install, then connect printer (or follow installation instructions, if different)
Also, just to make sure, plug it in a different USB port (after the reinstallation) incase the old drivers are stuck on the computer somewhere. Drivers usually/sometimes are associated with a specific usb port and will reinstall when plugged in a different port.
Mar 07, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Pictures wont down load
If the camera software is loaded and you are connecting the camera to computer.
Remove the softwaree and.
Windows will see the camers as a removable memory device in my computer an put up the scanner camera wizard.
This may reveal more.
You may also have inadvertantly deleted stuff
download www.pcinspector.com
install it to recover any deleted images.
Also try the camera and card in another computer.
Aug 12, 2008 | Cameras
Deleting all the pictures on the camera at once....
Unfortunately, there is no option to do this on the camera. I would recommend connecting the camera to the computer and then delete from there. It will be way faster and easier.
Jun 16, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
VuPoint PDSST410VP Logo
89 people viewed this question
Top VuPoint Office Equipment & Supplies Experts
Lawrence Oravetz
Are you a VuPoint Office Equipment and Supply Expert? Answer questions, earn points and help others
