Question about Refrigerators
Where does the spring on the door hinge of my zic360n monogram refrigerator hook? it has come undone and I can't find where to attach it.
Krames
  • 18 Answers
SOURCE: Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Posted on Nov 14, 2008
  • 1214 Answers
SOURCE: GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Posted on Jan 24, 2009
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
louislevel_2
  • 374 Answers
SOURCE: the freezer works fine but the top is warm
hi there,
there are several factor to be consider in this problem
thermostat is not functioning properly- check if busted replaced
capillary tube clogged- check capillary tube if there is ice
develop in part of capillary tube if clogged up-purge the
system.
Under charged on refrigerant-check by clamp ammeter
this solution should be done by certified ref/ac technician.call in to your service center.have a nice day
Posted on Jul 04, 2009
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Posted on Aug 19, 2009
How to instal an oven door on an ILVE stove?
I am pretty sure the door goes on the hinges go in the bottom of the door just slide in the bottom and door comes of the same way
Jun 01, 2014 | ilve Majestic Collection UM76DMPVS 30"...
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Oven door spring model av 669 26a
MFG Part Number:WB9K4 if spring is red -MFG Number WB9K5 if spring is black with a spot of blue paint. To access the spring remove the storage drawer. One end attaches to the hinge the other to a slotted hook. Check the opp. side spring to see how it is hooked up.
Feb 05, 2013 | Tappan TGF364AS Gas Kitchen Range
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
My Kenmore Elite freezer door came off one of its hinges. I cannot figure out how to put it back on so that it stays. The connection has an upper hook with a lower hinged arm. It is strange.
I just spent the better part of an hour on this. There is a white flange with two phillips screws. If you take this off it is easier to see the mechanism, but you may be able to get it back on without removing the flange. I removed the flange. The mechanism attached to the door has a hook facing up and a smaller hook facing down. There is a hinged metal bar below this. The bar has a hinged piece with a loop on it. Pull the loop up. Now push down on the piece with the hooks ( it has a spring) and hook the smaller hook on the loop. Do this for both sides. Now the door should slide easily into the slots. Once in the slots, push down on the hook piece and release the loop. Push the loop back in place along the bar. Hopefully this does the trick for you, it did for me.
Oct 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Red door spring GE monogram fridge side door
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Is a hinge switch possible
Most door swings are reversable and very easy to do. The owners manual should show if it's possible and how to do it.
Jan 30, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
